fj100 overheating in traffic any solutions??
Started by peter, March 16, 2010, 02:57:36 PM
peter
 :hi: my 1100 1984 fj gets hot in summer and overheats as this is a common defect of the bike has anyone developed a solution? larger oil cooler? spark plug change?
thks
peter
what do you mean by overheating?
what symptoms are you having?
Kookaloo!
Quote from: peter on March 16, 2010, 02:57:36 PM
thks
peter
Welcome to the group Peter.....your email address suggests you are in Italy...... I don't think we have any other members from Italy yet.
FJs do tend to get hot on slow commutes on hot days. One member here has fitted a fan under the tank above the valve cover, some have fitted computer type fans in front of the oil cooler. Many have swapped out the OEM cooler for one that is similar height but twice as deep. A good idea is to fit an oil temp gauge just so you can keep an eye on it. I doubt changing plugs to a cooler heat range is going to do much to engine temp.
I live in Tucson, AZ.... 100-110F+ during the summer. I ride year-round and have not had any overheating issues with my '90 except when I  got stuck in a traffic jam, once.... now I avoid them.
NOT a common "defect"..... what makes you think she's overheating?
Hello Peter,
I also live in the desert, and summers are brutal both on our aircooled bikes and riders.
Please describe your bike for us, mileage and any modifications.
If stock, I have 3 words for you... Jetting, Jetting and *Jetting*.
The '84's ran lean from the factory.
The largest oil cooler you can fit, and the best synthetic oil will help, but not still not cool the bike down if you are running lean.
teeeeeceeeee
+ 1 for Jetting.
I ran a high comp 1100 with stock oil cooler in the tropics & NEVER had overheating problems.
TeeCee
ccsct203
Sorry for the size
the real one is larger still
This works for me
the largest "bolt-on cooler I could fit
scottg
My '84's idle mixture adjustment was set too lean due to a failing sniffer at the dealer, it ran really hot in traffic until it was readjusted correctly.
peter
Quote from: racerman_27410 on March 16, 2010, 04:06:08 PM
Kookaloo!
:drinks: well my symptoms are sluggish gear changing, and an increase in rpms by about 500
peter
Quote from: Pat Conlon on March 17, 2010, 02:53:55 PM
Hello Peter,
great thanks will do
peter
Quote from: Harvy on March 16, 2010, 04:47:28 PM
thks
peter
Thanks will do yeah in rome with my FJ next is Greece
peter
Quote from: ccsct203 on March 18, 2010, 02:33:47 PM
Sorry for the size
This works for me
Is this real?? dont you have problems with air flow to back of engine which could create a larger issue?
Good instinct Peter, I agree with you. Remember our bikes are aircooled, not oil cooled. There has to be a point of diminishing returns when blocking airflow to the top of the cylinder head with a large oil cooler.
Oil coolers shed heat when air is flowing, but not so well in stop and go traffic.
If you want to reduce your cylinder head temps, again, fatten up your mixtures.
Quote from: peter on March 20, 2010, 10:58:43 AM
Yep, especially idle mixture.... the Japs were running very lean idle and off-idle for emissions reasons. These big-bore bikes run the emissions certification tests at very small throttle openings so they didn't mess with mains or needles too badly..... I went up a size on the pilots in my '90, from 37.5 to 40. It made a big difference....
ccsct203
Sorry for the size
This works for me
No issue with air flow
Engine stays cooler then I would have thought
I still get air over the head
