Top cap pin cut off, What's up with that?
Started by Timmer, January 13, 2017, 06:26:50 PM
Timmer
I'm going through the forks on my '89 and when I pulled out the top cap, I see that the pin that normally extends down the top of the fork has been sawn off.  Is this a typical mod?  What are the consequences?
Tor-King
I believe that is typical if you install an aftermarket fork valve.
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1984 Honda Nighthawk S 750
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
The RPM valves I installed had me cut that D-rod, not flush like your image. The damper unit is set to the middle setting and the RPM valves really do all the work. Time to pull the forks and find out what was installed.
Timmer
This was at the bottom of the spring.  I don't see it called out in my Haynes manual.
