Unknown object falls on the floor
Started by Maskina, January 11, 2017, 11:29:13 AM
Maskina
***Am I posting right? Total new beginner. Bare with me.***
Finishing bleeding the clutch slave cylinder, I moved the bike from it's centerstand. Then this spectacle dropped down on the floor [see attached pics].
I can't find it's origin, so I ask for advice. Does anyone know where this piece belongs? Most importantly is to know if it's vital or not.
FJ1200 '91.
Something tells me it's part of the battery-box, but I'm sure someone else will chime in who knows for certain   :pardon:
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
It looks to me like one of the front fairing mount tabs?
Possibly one of the ones behind the side air scoops?
Looks exactly like the tabs I broke off from either side of the head lamp. I learned how to weld ABS the very next day thanks to Mike (Skymasteres).
Urban_Legend
Looks a lot like the headlight tab.  Only way to tell for sure is to remove the fairing and have a look.
Mark
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
The fastener is wrong, on my '86 and '89 it is a 10MM hex head bolt. So it might be from the side panel. The J-Nut (Spring nut) looks the same.
whyzee79
Unbolt it and see what's sandwiched inside the clip.  That might tell you where it came from.
Maskina
Hello again.
Possibilities:
Part of the battery-box.
Front fairing mount tab.
Head lamp tab.
Side panel tab.
I'll update once I find it's true origin. Maybe I'll be able to learn ABS wielding myself.
Thank you all for your fast response.
Quote from: Maskina on January 12, 2017, 02:09:57 PM
Hello again.
Possibilities:
Head lamp tab.
Side panel tab.
The material on the far right, is that foam? or foam-like?
'06 KTM 200XC
I will add another possibility...... The thing that I notice is two layers of plastic. Too me the square piece that had the spring clip on it is a main fairing tab. The other piece could be from the aft mount of the air scoop. The only place that I know of that has two layers of plastic are the three air scoop mounts to tabs in the main fairing.
Maskina
Quote from: Dads_FJ on January 12, 2017, 02:43:52 PM
Hello.
It sure looks foam-like. Although, just like the sandwiched piece, it's also hard plastic.
Maskina
Quote from: aviationfred on January 12, 2017, 04:27:37 PM
That is noted. Maybe I'll be able to locate it without removing the fairing.
I'll be plenty satisfied if I know where it's suppose to go. Fix can wait.
gumby302ho
 It looks like the tab broke off from the stock exhaust is my guess,
gumby302ho
Quote from: gumby302ho on January 20, 2017, 07:51:47 PM
  Sorry I should have read a little further as its made of plastic. My bad.
Mike 86 in San Dimas
from your car. :mail1: My guess is it is not vital, maybe an air box fastener
