Clutch slipping after rear wheel swap
Started by aj52, December 12, 2016, 12:41:40 AM
aj52
Happy with handling after rear wheel slip.
Took bike on a sunday afternoon trip off about 150km to test it through some curves.
On my way home,I opened throttle a bit and clutch starts to slip :shout:
Slowed down and open it again full throttle,slips again.
Ride home at 140km/h,very pissed and parked bike.
I have read the clutch files what to do to solve the problem.
My question: Is there any special tool that is needed to do clutch work?
Thanks
Hannes
1991 FJ 1200 ABS
1991 FJ 1200
Old Rider
I guess you already know but if you have changed motoroil lately its important that you use a motorcycle motor oil.If you use a synthetic based oil not made for motorcycle with clutch and gearbox bathing in the oil you might experience slipping clutch.I can recomend yamaha lube semisynth.
Pretty easy to do. Here is a good read. http://www.fjowners.com/index.php?topic=1808.0.  You don't even need to drain the oil if the bike is on it's side stand. You might consider having a new clutch cover gasket on hand along with the clutch disks and steels if you need them.
aj52
Quote from: Old Rider on December 12, 2016, 01:39:24 AM
Thanks for the reply,but no,I didn't change oil after wheel swap.
Bike run Castrol 4T motorcycle oil in it.
It had slippich about 5000km back caused by wrong oil,but since I ran the Castrol,this is the first time.
If I accelerate normally,it is fine. It slip under hard acceleration
1991 FJ 1200 ABS
1991 FJ 1200
aj52
Quote from: movenon on December 12, 2016, 03:43:29 AM
Thanks George
I had read this same thread this morning.
I just want to know if there is any special tools involved.
Pat answered me on that
If I get trouble a long the line,I will ask for help with it
1991 FJ 1200 ABS
1991 FJ 1200
Motofun
If the engine has been worked on, ie stage 3 kit etc, you may need to add an additional clutch diaphragm spring.  I did this to me '85. the clutch pull is that much harder, I put the FJR Master cyclinder on it and it helped some, but still requires an added effort.
'75 Honda CB400F
'85 Yamaha RZ350
'85 Yamaha FJ1100
'89 Yamaha FJ1200
'09 Yamaha 125 Zuma
'13 Suzuki GSXR 750 (track)
'14 Yamaha FZ-09
'23 Yamaha Tenere 7
bigbore2
a new clutch spring should do the trick.  But while your in there.......upgrade.
JOMPPA10
Quote from: aj52 on December 12, 2016, 12:41:40 AM
Thanks
Hannes
hi how old are your clutch plates, because mine started to slip suddenly..
Seppo
