RPM Rear shock update
Started by Bozo, November 03, 2016, 07:00:57 PM
Bozo
Quote from: ribbert on November 08, 2016, 05:57:20 AM
Quote from: Pat Conlon on November 07, 2016, 11:30:30 AM
Noel, remind us, what suspension do you currently have on your FJ?
RPM front fork goodies and a gas shock.
Now this fits I was sure you mentioned the same suspension components i.e front & rear RPM, and here I am trying to work out why the rear on yours is different.
Please read my previous comment again, did I mention gravel rods or just rough roads, its obvious the BMW is better on dirt roads with corrugations I won't argue there.
I'm sorry I started this post.
Bozo
Quote from: ribbert on November 08, 2016, 05:32:45 AM
Quote from: Bozo on November 07, 2016, 05:04:40 PM
....convinced me to change the rear tyre to a 17" GSX750, yesterday it arrived. To my amazement it was (approx) 600mm dia with a 150/60 x 17" tyre. My FJ 16" has 650mm dia.....
Bozo, something doesn't seem right there. It has always been generally accepted, that the OD of the 16" with the taller standard tyre is much the same as a 17" with a 180/55, which is what I run, and I would imagine was the most commonly fitted size. 50mm is a huge difference.
From memory, the gap between the wheel and ground barely changed when I swapped, certainly not a significant amount or enough to affect anything.
....and he still commented that he was blown by the way my bike rides over rough roads.
I travelled the corrugated gravel roads between Wilpena Pound and Arkaroola mostly at 80 - 100 kph and at times hitting 160 on the dirt, the suspension was great.
The Kwaka looks like a lot of fun.
Check tyre sizes here on the link below. Remember I stated "AN APPROX" (please read again) 600mm on the 150/60 x 17 (611.8mm - quoted on web with NEW tyre, mine was 60% worn) so 600mm is not bad.
My 150/80 x 16 was quoted at 650mm APPROX (646mm 0n web) so my ROUGH measurements were pretty good.
https://www.tacomaworld.com/tirecalc?tires=150-60r17-150-80r16
Bozo
Noel, sorry I got a bit heated about this discussion. I take your/ everyone's points on board. I'll let you know how my 17" conversion goes, if its as good as Arnie and Pete say it is, I can't wait.
Thanks to everyone for participating , now we can concentrate on how Trump will affect Australia.
Quote from: Bozo on November 09, 2016, 03:43:10 AM
.....now we can concentrate on how Trump will affect Australia.
It 'aint good.
Quote from: ribbert on November 09, 2016, 05:00:18 AM
It 'aint good.
Probably less good for Australia than for America, which is fine, since it's been the other way around for some time.
Just because this is kind of a confusing statement by Noel.
Unless Noel changed over to the stock Yamaha shock or a different aftermarket shock, he is also using the RPM shock in combination with the RPM fork valves.
