Back of the dragon and BRP
Started by fudge12, October 31, 2016, 01:10:54 PM
fudge12
So the good newsish is that the noise was a couple loose rivets on the cobra exhaust on the FJ, which were easily replaced. And it stopped leaking gas, which I assume was due to crappy gas and no fuel filter.  I'm on the list for the shim kit, so when I get it I'll go ahead and pull the carbs and make sure they're clean and the mounting boots are still good.
And another bit of noise was a crack in the chin fairing, which I'm ABSing back together. Spent the day cleaning, polishing, etc both bikes as part of the post-ride maintenance. Anyone else do that after a long ride?
Other random thoughts, I probably pushed the boy too hard with the long days.  Should have either stopped more often or done a longer trip (timewise) but had to work in the days I had.  The blast is a great little bike, but with the ~120mile range before reserve there were more than a few times I felt uncomfortable.  If I were to do it again I'd either bring a rotopax for extra fuel, or figure out some easy way to transfer fuel from the FJ to the blast.  The FJ is just about a supertanker comparatively, so I wouldn't miss a gallon or so every hundred miles.
1987 FJ1200
2008 Versys
2002 VFR800
2002 Buell Blast
1986 Honda CM400C
~Dnepr MT-16
1975 Honda GL1000
The best you've ridden is the best you know.
I'm like Netflix, but with bikes.
fudge12
Good news all the way around from Blackstone Labs.
1987 FJ1200
2008 Versys
2002 VFR800
2002 Buell Blast
1986 Honda CM400C
~Dnepr MT-16
1975 Honda GL1000
FeralRdr
Thanks for sharing the adventure.  Picts of your '87 bring back fun memories of mine.  :hi:
fudge12
Thanks. It's nowhere near as crazy as some of the ones I've read (it seems that strife and challenge make for excellent ride reports, as do pictures of a bike balanced on a rock while tires are changed) but I'm totally willing to accept how well this one went, and still impressed with the boy.
1987 FJ1200
2008 Versys
2002 VFR800
2002 Buell Blast
1986 Honda CM400C
~Dnepr MT-16
1975 Honda GL1000
Country Joe
Great ride report! It's prodding me to plan a longer ride for son and I than just a half day ride in the hills.
1993 FJ 1200
