rear tyre what make or size! do you use?
Started by Russfjr1, October 21, 2016, 05:06:54 PM
JOMPPA10
Quote from: Pat Conlon on October 21, 2016, 07:01:03 PM
I recommend the Avon Storm 3D X-M radial 150/80-16
http://www.revzilla.com/motorcycle/avon-storm-3d-x-m-tire
Review: http://www.sportrider.com/avon-storm-3d-x-m-tires-sr-tested
i use metzeler lasertec front and rear in my old (90) 1200 any thoughts of that? iam not anykind guru of tires, maybe better ones next
season
krusty
FJ1100 I'm using Duro F - 120 x 80 16" HF918. R - Duro 150 x 80 16" BLVD X896
FJ1200 Metzler Marathons F - 120 x 70 17". R - 150 x 80 16"
I'm quite happy with the performance of both brands but then I don't ride anywhere near 10/10ths. I can't comment on longevity as they are fairly new.
My previous FJs (2) I used Dunlop Sportmaxx. These were great all rounders but not available here anymore in 16" sizes. I would get 15000klm rear and 17000klm front.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
Country Joe
Quote from: JOMPPA10 on October 25, 2016, 11:09:10 AM
season
I had a set of Metzeler Lasertecs that came on my first FJ. I really didn't have any complaints about them. I replaced them when I wore them out with Avon Azaros, which I preferred greatly.
1993 FJ 1200
PaulG
season
I've gone through two sets of Lasertecs.  I got very high mileage and good wet weather performance.  Old technology but reliable.  A more touring than sport tire.  I switched to the Avons listed above this year cuz I've never had radials, and they were also cheaper than the Lasertecs oddly.  I don't know what mileage I will get ultimately, but the handling and ride comfort is much improved.  I have a bone stock suspension also on my '92 ABS.
1992 FJ1200 ABS
YouTube Channel Paul G
There are a few members that run the Metzeler Lasertecs on the 16" rims. I am sure the rubber compound has changed from 30 years ago when the tire was a very common choice. I have also come across a tire model that is of the same type of "old school" design that was also a very popular tire 30 years ago. The Continental TKV11/12 tires. The front is offered in a 110, but IMO with the 2.75" wide wheel, that should not be a problem. The rear is OEM size 150
