Koenigsegg free valve technology
Started by Pat Conlon, October 21, 2016, 12:06:34 PM
Charlie-brm
Here is a valve cover cut away of an operating BMW car engine revving to 14,000 rpm. Contemporary DOHC with springs engineering. Fun starts at 00:50
https://youtu.be/tKPJHq9hzEQ
It's almost painful to watch and I don't put my face too close to the monitor, LOL. How engines don't fly apart and turn into portable particle colliders just impresses me all the time.
1979 XS750SF - 2005 to 2012
FeralRdr
Quote from: Pat Conlon on October 21, 2016, 12:06:34 PM
Recently I was peeking under a cover at an unnamed motorcycle shop and noticed a FJ cylinder head with the cams missing and all the cam journals milled out and recessed into the head, some sort of strange valve actuators with small hydraulic lines running to them.
Hmmmm, no cams?
Then last week, I saw this in my news feed:  http://www.popsci.com/9-greatest-innovations-in-automotives-this-year
Further investigations: https://www.youtube.com/watch?v=f4p-55a3WV8
So any truth to the rumors an RPM Flux Capictor is in the works too?  :good2:
TexasDave
                                                   10 years in the future
This Koenigsegg computer controlled valve technology is great. Can select one mode for max gas mileage for touring. Second mode for max power with the computer automatically adjusting the timing, EFI, valve lift and duration. All done while travelling down the road. Then there is boost mode activated by a button for far more power. Timing, EFI and now both valves opening and closing on every stroke. Now have a 1200cc TWO STROKE. 30% more power. Only good for short periods and gas mileage is crap but who needs a TURBO?
Dave
The talk of using the engine as an air compressor on deceleration was interesting...
...and no throttle plates to control airflow to the cylinders....
Quote from: Pat Conlon on October 24, 2016, 02:00:42 AM
Pregnant with possibilities...  Maybe the good 'ol internal combustion engine hasn't quite given way to the coal-fired electric crapcans just yet...  :)
Russfjr1
When I was working at Koenigsegg on the development of the powerplant all be it mostly v12 AMG we figured that with tweaking the tec we could knock off 4 cylinders thus using a v8, buy filling on board air tanks via pistons on over run with sufficient air pressure to take place of the turbos and give a rise of 34% power per litre. This we put to test on a Nissan Micra 1.0 made in 2001 with if memory serves 53bhp (at the engine not wheels). We made the head for it minus the cam and with a few other modifications to the inlet and exhaust tracks we managed 68% increase to 89bhp
OK i agree 89bhp is low but 68% is phenomenal, Just think if your bike or car or whatever machine has say 187bhp that goes to 314.16bhp combined with a cleaner more fuel efficient engine
It's about as useful as a chocolate fire guard
Current bikes in the stables
Yamaha FJ1200
Yamaha FJ1100
Honda Monkey-bike z50m 1967
Ducati Monster
Ducati ST2
Triumph Daytona 600 (daughters)
Honda CBR1000RR (daughters)
Quote from: Russfjr1 on October 24, 2016, 01:38:52 PM
When I was working at Koenigsegg ...
WHAT!?  HOLD ON HERE!
Any chance a few "prototypes" could make it out the door for the 2018 attempt at the Colorado Mile?.....
gumby302ho
Quote from: racerrad8 on October 21, 2016, 08:54:42 PM
Watch the valve float at about 1:36 when the springs start to turn....
https://youtu.be/nsa6kq-qqIE
You want the valves to turn like this so they do not pit the seat or the valve. It starts around :56
https://youtu.be/vcyT18qk8ls
Electric/oil/air valves eliminate this valve float...F1 has been using this technology for years. That is how a F1 engine can turn close to 20k plus
This shit is bad ass...CRANK UP THE VOLUME (click the boxes off the video if they pop up)
https://youtu.be/iWSt4CDNvgQ
 I believe F1 engines use nitrogen instead of air for valve actuator setup from what I have read, not sure of the benefits of either method.
PaulG
When I was working at Koenigsegg ....
And I thought you were just a gifted backyard mechanic.  Now you've blown your cover!   :lol:
Quote from: gumby302ho on October 24, 2016, 07:18:13 PM
I think they use nitrogen in their tires also.  Reason is that it expands much less under heat than air, thus maintaining a stabler tire pressure.  Maybe a related reason for the air valves?  :unknown:
Heres a vid from MotoGP - a few years old now - but interesting still.
MotoGP Workshop™ - Pneumatic valve engines
An article related to the vid
How Pneumatic Valves Work in MotoGP
Now I know why they are making such insane amounts of horsepower now.  This would explain why these bikes are unrideable without the electronics.  Maybe we'll see another change in engine spec soon.  3 cyl max? 500-750cc?
But if they sounded like this I'd be happy if they only went 100mph
Honda RC166
1992 FJ1200 ABS
YouTube Channel Paul G
Mike Ramos
Quote from: FeralRdr on October 23, 2016, 05:06:41 PM
Hmmmm, no cams?
I was recently at the RPM shop and prompted by Pat's initial post I also looked under the covering:
Hmm.... not sure about a Flux Capacitor but Pat, if you had looked a little closer into the details,  perhaps you would have imagined the increased valve angle (blank head as in the V & H's drag bike) thus allowing for more modern flow characteristics - when coupled with the valve actuators mentioned I can imagine very impressive HP & torque numbers...
Thanks for the suggestion Pat, it keeps things interesting and light hearted.
Midget
Russfjr1
:biggrin:   Me working at Koenigsegg   :blush:  who'd a thunk it   :rofl2:   well you have to have a laugh now and again don't you  :mocking:  Sorry just a little porky pie, but I did do my apprenticeship at this little backwater company called Rolls Royce, now that place taught me a multitude. Looking back they were definitely the best days of my working life.  Happy days indeed   :drinks:
Yamaha FJ1200
Yamaha FJ1100
Ducati Monster
Ducati ST2
