T Rex Bimota YB5
Started by stua1959, September 29, 2016, 06:49:05 AM
Quote from: oldktmdude on October 01, 2016, 09:41:23 PM
Quote from: gumby302ho on October 01, 2016, 03:14:59 PM
  Any idea of the loss of hp at the crank through the drive? I could guess maybe 35hp
According to the dyno technician that did mine, a loss of around 18% is not uncommon at the back wheel.
Pete, wouldn't the loss at the back wheel be a constant, not a percentage?
I was thinking the same thing. If you have a 10hp motor you wouldn't lose much. But those turbo guys must have a brake locked up.
Bill_Rockoff
Quote from: ribbert on October 02, 2016, 07:49:29 AMwouldn't the loss at the back wheel be a constant, not a percentage?
No, the more you put into a mechanical system that has friction losses, the more you lose. I can't think of a way to build something that always needs a fixed amount of power to move. A fixed amount of FORCE, maybe, but the faster you apply that force, the more power it is.
If you had a system with a constant loss of, say, 10 hp, you wouldn't be able to move it at all with a 10 hp motor. I'm having trouble even picturing a thing you couldn't budge with a 10 hp motor.  That's a motorcycle that you and half a dozen friends couldn't push, because each of you makes maybe 1 hp max.
But on a normal actual system of parts, if you put in a little power, you lose a little and get the rest out; if you put in more power, you lose more.
18% is pretty typical for a rear-wheel-drive car with a manual transmission. You lose a bit in the transmission gears, a bit more than that in the rear diff, and a little in the drive-shaft and half-shaft's CV joints. A solid-axle car does a little better because there are no half-shafts. A transverse-engine car, like most front-wheel-drive setups or like a mid-engine transverse car, does a little better than that because there's no 90-degree change of rotation in the diff, all the shafts rotate in parallel axes. A typical torque-converter automatic does a little worse. A motorcycle with a chain or belt drive does better (I've read "15%" but a shaft drive is back to 18% or more, depending on whether its driveshaft has a 90-degree gearset at each end or just at one (longitudinal crankshaft like a Honda ST or a Moto Guzzi or a boxer BMW.)
Quote from: Bill_Rockoff on October 02, 2016, 09:10:50 AM
No, the more you put into a mechanical system that has friction losses, the more you lose....
True, but is the increased loss proportional to the increased power?
Quote from: giantkiller on October 02, 2016, 06:18:53 AM
So Pat has the 1380 cured the oil consumption problem?  And I don't remember what happened to cause the rebuild?
The top end coked up from excessive oil. I had the 82mm Hank Scott Prolite short skirt pistons.
I decided to change course and use the conventional Ross 83mm long skirt pistons.
All is well since.
oldktmdude
Thanks for your answer Bill. That's what my reply would have been but you have explained it far better than I could have. Every dyno figure that I have seen, always quotes the rear wheel hp loss as a percentage. During the first dyno run that I did, my drive chain had a tight spot in it and this showed up as a intermittent loss of around 5 to 8 hp. Just shows how  relatively small changes in friction values can effect the output figures.
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Quote from: Pat Conlon on October 02, 2016, 11:18:16 AM
All is well since.
I have an APE block and a Wisco block (cylinders). I can't remember I think one was 1380 and one was 1450? I've had them for while. Was thinking of using the Ross pistons. And seeing if Randy might want to build me a couple of monster motors. In a couple of years If I can gather enough money.
Flynt
doesn't make sense...  let's say it is a constant 15 HP.  Would the bike make negative Hp below the "drivetrain loss" Hp of say 15Hp?  It is, of course, a percentage.  It is not truly linear however... but that's beyond the scope of this discussion.
