I Spy.......
Started by ribbert, September 06, 2016, 09:15:16 AM
This is from an ad for an FJ for sale.
What can you see that (a) Makes it impossible to ride(other than no fuel tank)
                               (b) Ill advised to ride.
Well having red nuts might make it hard to ride.
Bill_Rockoff
Where do those throttle cables go?
The valve cover bolts look they might be loose.
Missing the SST fastener kit from RPM.
The yellow connector condition looks questionable.
No choke knob (but that goes on after the fairing).
The engine looks cleaner than the bike, like engine work has been done recently.
Looks like the speedo cable is not connected, both ends are visible.
Choke cable is not connected to the carbs.
Quote from: FJmonkey on September 06, 2016, 09:52:41 AM
Monkey, I think you are close with this one but...
I do not see any valve cover bolt grommets or valve cover gasket present.
Also, things I see that have not been mentioned.
No throttle cable bracket on the carbs to mount the cables.
Choke cable not hooked up. (laying off to the left side of head)
No plastic throttle box to hook up the throttle cables.
Maybe it is just the photo...But I do not see a front tire either.
Already mentioned.
Throttle cables heading the wrong way.
Vacuum cap missing
The photo is not clear enough to be able to see more details of the recent head work.
PS. Monkey, those two cable ends are the upper throttle cables.
4everFJ
Quote from: giantkiller on September 06, 2016, 09:28:26 AM
I second that! Never - EVER - ride with red nuts.....  :wacko1:
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
PaulG
1992 FJ1200 ABS
YouTube Channel Paul G
Burns
Quote from: 4everFJ on September 06, 2016, 11:57:21 AM
I agree, those radical communists are terrible riding partners. they always want YOU to pay for the gasoline!
PaulG
Quote from: giantkiller on September 06, 2016, 09:26:53 AM
Vacuum plug/cap missing
Quote from: racerrad8 on September 06, 2016, 10:26:56 AM
Already mentioned.
Vacuum cap missing
Crap.  I can pick out a missing vac cap, but I can't read a thread.   :pardon:  I guess I miss the grand prize trip to the Grand Bahamas.   :empathy2:
1992 FJ1200 ABS
Earl Svorks
   I do not see any exhaust header pipes. It would sound a bit odd.
   Simon
Earl,
Thanks for reviving this topic....the answer has gone un-answered.
Noel, what was the results of the answers provided...inquiring minds want to know.
fudge12
To me it looks like an in-process picture showing the work that was done, probably taken just after painting the valve cover.
1987 FJ1200
2008 Versys
2002 VFR800
2002 Buell Blast
1986 Honda CM400C
~Dnepr MT-16
1975 Honda GL1000
The best you've ridden is the best you know.
I'm like Netflix, but with bikes.
Shane4371
#1 vacuum port capped should run to fuel petcock,#2 vacuum port needs plugged,chock cable not hooked up.could be hard to start cold
I still say it's the red nuts!
