studs leaking
Started by CanDman, August 30, 2016, 09:14:16 PM
CanDman
As some of you may know....CanD (my 85) was sent out to have the bottom end done(quite some time ago) by the most reputable guy in Canada.... an older guy with a reputation as good as it gets. Anyway.......he ported and polished the engine along with a list a mile long of other stuff he did as well.......well once the engine was done, I sent the bike to another shop to install the motor as well as the new carbs and tune it.......after finally resolving the few issues with the new carbs, he fired her up only to find 2 studs on the right side leaking  :dash2: :dash1: :dash2: :mad: :flag_of_truce:  :dash2: :dash2: :dash2: :dash2: :dash2: ...... I probably need to take the motor back to the guy....but I also need a word of encouragement.....so bummed.... :cray:.......just seem to be hitting one road block after another.........chasing the wind....the wild geese as well as my tail.....and I'm feeling so bummed out.... :diablo:.... I don't need any sunshine blown up the ole tail pipe but if someone can tell me what might be the reason and what might be involved in resolving this leak.....I am hoping to ride her this year before the season ends :empathy3: Thx
Kev
oldktmdude
   G'day Kev, if you're talking about an oil leak, there are two rubber oil seals that fit between the head and the block , two outer most studs. (RHS) These may have been left out when re-assembling.
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
CanDman
Quote from: oldktmdude on August 30, 2016, 09:28:39 PM
   Regards, Pete.
thx Petey.......I think I love you  :cray:
Kev
Kev, it may not be so bad....if you are talking about the cylinder studs where the nuts go to tighten down the head, there are copper crush washers that go under the nuts. Those 2 oil passages supply oil to your cams.
Steel washers won't seal. You need soft copper washers that will deform when you tighten down the head nuts to 25 ft/lbs.
If that's the area, your fix is easy peesey.
Cheers laddie
[edit] You'se guys are fast.....Petey beat me to it.....
CanDman
You guys are the best !!!!  :cray:........  :drinks: (I filled yours with apple juice Pat....  :hi:)
Thx Patty and Petey
Kev
CanDman
Is it leaking at the nuts or between the fins at the gasket surface?
If at the nuts, you need the washers Pat posted. If between the fins the head needs to be removed and the dowel seals installed.
http://rpmracingca.com/proddetail.asp?prod=90430-14240
CanDman
Quote from: racerrad8 on August 30, 2016, 10:03:11 PM
Thx Ranbo.......I sent you 3 emails  :blush:......sorry.....but I will take em.......the washers and the dowel seals...... :drinks:
Kev
I think you are thoroughly screwed CanDman -- I'll do you the favor and take her off your hands next time I'm up that way - you'll only have to provide the beer!   :drinks:
Seriously - sounds like everyone has you taken care of - just a small hiccup to getting her back on the road!  Good luck!
CanDman
Quote from: fj1289 on August 30, 2016, 10:29:44 PM
Thx for that.......everyone who responded did an excellent job lifting my spirits.....so I will gladly provide the Lager's and Ale's to anyone willing to make it up here..... :good:
Kev
oldktmdude
Quote from: CanDman on August 30, 2016, 10:36:01 PM
Kev
I'll collect mine when you get your arse back over here!   :drinks:
   Regards, Pete.
2009 TDM 900
2004 GasGas Ec300
CanDman
Quote from: oldktmdude on August 30, 2016, 10:41:32 PM
Kev
   Regards, Pete.
Sounds good Pete.......and that may be sooner then you think.... (popcorn)
When I do major maintenance or have a parts related question. I mostly refer to Partzilla.com for part location and assembly. I don't usually order parts from them, but it is a great site as a reference tool.
http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1985/FJ1100N/CYLINDER+HEAD/parts.html
#13 and #14 are the stud washers.
It is really helpful when buying used parts. If you click directly on the part number. You will be shown a page that lists every model that the part is used on.
Here is an example: I clicked on the #14 part number and got the following page. http://www.partzilla.com/parts/detail/yamaha/YP-90201-10128-00.html If you scroll done, you will see that the copper washer is still used in models up to the currently produced Yamaha/Star Bolt v-twin.
CanDman
Quote from: aviationfred on August 31, 2016, 08:14:48 AM
That's awesome Fred....does it come with a RALLY T-SHIRT.......  :rofl2:
Kev
PS........you need to get up here for a visit.....got some dash work for ya  (popcorn)
