Suspect a misfire...
Started by LtPwnzor, August 21, 2016, 08:03:21 AM
LtPwnzor
So I'm back to my 92 FJ after over a year of being out of the country. I was riding the other day, and as I was pulling into the garage I could swear I heard a sort of "chuff-chuff" from my machine. She's also been very hard on gas, harder than I remember since my departure last Spring. I'm kind of worried.
Try not. Do, or do not; there is no try.
Sitting for long periods is bad for the carbs. Did you prep the bike before parking it?
LtPwnzor
The bike has been run regularly (no less than once every few weeks) since I've been gone. I had noticed this developing even before I'd left. During the weeks just before my departure, I had heard and felt it missing when the bike wasn't warm.
Not a lot of information to help you with at this point. Start checking the easy stuff. Plugs, plug wires. Spray WD40 around the carb boots while under idle, possible vacuum leak.  :scratch_one-s_head:
Russfjr1
Totally agree duff plugs or an air pipe of some description has rotted (old age) then given up all together. Change the plugs have a good look at all the rubber pipes should be good to go.  If not might be time to look at carbs?
It's about as useful as a chocolate fire guard
Current bikes in the stables
Yamaha FJ1200
Yamaha FJ1100
Honda Monkey-bike z50m 1967
Ducati Monster
Ducati ST2
Triumph Daytona 600 (daughters)
Honda CBR1000RR (daughters)
