chin fairing heat shield
Started by Joe Sull, July 13, 2016, 04:59:15 PM
I ordered a chin fairing from AirtTech today. Anyone seen a thread on the heat shield material source? I thought that I had seen one but I haven't had any luck with the search engine.
CanDman
Quote from: Joe Sull on July 13, 2016, 04:59:15 PM
Let me know what you find Joe.....I just grabbed 2 chin cowlings myself and I would also like to protect the lining..
CanDman
Tuneforkfreak
Yamahas from my past,
IT465, IT200, YZ80. 350Warrior, Kodiak400, Kodiak450,
Various others include
XR600, KX500, KDX200, ATC250R, ATC350X, ATC 200S
Currently ride
FJ 1200 , DRZ400, Yamaha Viking, Suzuki Samurai dirt mobile
FeralRdr
Here you go: chin fairing
Check the bottom of the thread for a couple of recommendations
Quote from: Tuneforkfreak on July 13, 2016, 05:35:04 PM
Is this the stuff you're looking for?  http://www.ebay.com/itm/Heat-Shield-Protection-Aluminum-with-Fiberglass-and-adhesive-layer-PROFESSIONAL-/400865420348?hash=item5d5570e43c:g:KzEAAOxyoA1RM7Ff&vxp=mtr
It certainly looks like the stuff. looks like the shield on the bottom of the gas tank.
The thread I was referring to in my previous post had a pattern to printout and cut. I might be confused. Maybe it was the tank heat shield.
PS: Thanks FeralRdr for the post.
I got the little fairing on today. Air-tech did a good job. A little wet sanding got the paint to stick.
The rear holes are bossed so I drilled those first with a 1/8 inch drill then opened them up to expose the
threaded mounting tabs. Once I had the rear screws installed, I was able to spot the front holes from the inside
with a piece of pencil and needle nose plyers.
This winter I'll put some rubber grommets in the holes, but for now I won't tighten the screws up.
I have them a little loose so I won't crack the glass. I bought the heat shield material that
Tuneforkfreak showed on ebay. It appears to be working good. I took a good ride and the glass
is only warm.
I took a look at fj monkeys pattern. It looked to me like it would be for the fj1200 and not the fj1100
I just traced the fairing and cut it out best I could. The adheasive backing is good and sticky
and should stay stuck.
I'm glad my bike is complete now. Thanks for the help.
Either use a shoulder bolt or make your own spacer to avoid clamping the plastic directly.
The stock method used spacers/collars for the bolts.
jscgdunn
Hey Joe,
Where is the red mota? :pardon:
Jeff
90 FJ 1200 (Son # 2), Stock
Hi Jeff. The duplicolor red anodize turned orange and the heads turned yellow. It was a real hassle getting it off. almost as hard as removing the black.
Thanks Chris for the RPM parts list I'll order what I need.
jscgdunn
JMR
Fits well..good job mounting it.
