Which Spark plugs?
Started by Sparky84, June 25, 2016, 03:19:39 AM
Sparky84
Hi All
Having a slight spark problem at present I think, plugs are always black
I've been using NGK DPR8EA-9 but specs say DP8EA-9 if you're not in Sth Africa, so are the resistor plugs correct or should I be using non resistor ones?
Cheers Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
oldktmdude
   G'day Alan, I've been using NGK DPR8EA-9's since I've had my FJ without any issues. Plug colour is usually a little on the dark side but I have never had a plug fail. Are you having an issue with plugs fouling?
   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Sparky84
Quote from: oldktmdude on June 25, 2016, 05:09:03 AM
   Regards, Pete.
Hi Pete
I too have always used those only because stores only stocked those.
The #4 plug mainly, it actually could that much it would fire, took off cap bike ran the same.
Still looking into problem found on Dyno in Nowra that found issue with picking up revs on #4 lead.
Changed cap, now looking into voltage to coils and "coil mod with relay"
Cheers Alan
1979 Kawasaki Z1300
Sparky84
Quote from: Sparky84 on June 25, 2016, 05:41:30 AM
   Regards, Pete.
Hi Pete
Cheers Alan
Sorry Pete,
Spell check suxs ! Meant to read,
"The #4 plug mainly, it actually fouled that much it wouldn't fire"
1979 Kawasaki Z1300
a.graham52
Question u have.... is 4 misfiring because it's fouled or fouled because it's missing?
Are you positive number 4 carb is not over fueling?
If it is indeed ignition related, swapping coils and plug wired around will potentially show you the fault because the misfire will move to another cylinder
Sparky84
Quote from: a.graham52 on June 25, 2016, 01:44:19 PM
"Fouled because it's missing" I believe, as when dyno was being done they had trouble picking rpm from #4 lead, very intermittent.
I started it the other day for a ride and it didn't sound right, found #4 header dead cold (I was holding it with my hand, tight) after slight warm up and all other headers I could touch due to very hot. Changed that plug all OK?
I'm not sure if #4 carb is over fueling, tracing electrical first.
Cheers Alan
1979 Kawasaki Z1300
Sparky84
Found voltage at both coils plugs to be OK, 12.35v, so I didn't do coil mod.
Original caps ranged from 9.10 - 10.89k ohms, but also found 2 caps had loose cap screws, 1 seemed not to be screwed firmly onto lead(it was one with a loose cap screw)
Also small spring in cap was discoloured, I don't think it was corrosion as I believe it to be stainless.
Spark plugs ranged from 4.45 - 4.81k ohms
New caps ranged from 8.68 - 9.41k ohms
Cut back leads about 15mm and fitted new caps.
Cleaned plugs up and set gap to 0.85 (I swapped #4 for another after checking spark was not good)
Just need to take it for a run now
but do I use non resistor plugs resistor DP8 or DPR8
Alan
1979 Kawasaki Z1300
Alan,
I only use & sell NGK resisted spark plugs for the past twenty years of my FJ experience.
I have the standard plug and Iridium in both stock and one step colder heat range. Search NGK at the website and you can see the plug options.
Did you resistance check the coils on the primary & secondary sides?
99% of the time a black spark plug is a carb issue.
