Float height survey
Started by JPaganel, June 11, 2016, 10:59:06 PM
JPaganel
So, sometime last year I started at 19mm.
That leaked like a bastard.
I went to 20, then 22. At 22 it ran, but had a wet kind of a sound at 2000-3000 RPM and was crappy at low speeds.
I just got them to 25mm. Bike runs smoother, less backfiring.
What's everyone else running for float height?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Depends if you raised the rear end up.
I run .880 (22.23mm) with raised .
spend a lot of time above 6k and will get a small amount of popping with engine braking from high rpm.
when cruising around all is good.
