What did you do to your bike today?
Started by tqmx1, February 24, 2010, 08:37:12 PM
Started it!  Finally getting close to getting it back on the road again!   :good2:
Back to a stock motor and stock carbs with Factory jet kit, but at least she's almost whole again!     :drinks:
On my "other FJ (86)" put the head back on the engine, timed the cams, and adjusted the valves.  Will pull the pan next weekend and clean it out, then reinstall the lump back in the frame.
well sunday I rode it. then pulled the front wheel .
today I visited George and he swapped the tire off the fj rim onto the fzr wheel.
tomorrow is another day.
RumBoy
Installed my stainless braided brakelines. Aligned and tightened the back wheel. (Still have to check chain tightness (DOH!)) Put the tank on, put the seat on and fired that puppy up. Flabbergasted that after sitting unused several months in a freezing storage unit the battery wasn't cactus and actually cranked the lump over pretty good.
Took it for a gentle ride down the road, deafening the neighbours. Rode back to the storage and installed the mufflers. Rode back out again for a quick blast in front of the facility. MMMmmmmMMMMm that felt good.  :shout:
Left to do: Fix the fork seals. (groan) Get new tyres. Check valve clearances. Acquire and install front wheel guards. Attach windshield. Get some fiberglass and resin to fix the multitude of cracks/breaks on the fairing. Take to it with a brush and soap and water.
DILLIGAS
billwest
Quote from: Harvy on March 11, 2010, 04:42:12 PM
Bill, look up my cousin and his wife (Mark and Sue Holman).......they will be in attendance.
Yep, saw them!
I watched the parade on Saturday morning, around 2500 bikes.
If they had dinner in the big tent that night, I would have talked to them.  I talked to everyone.......
Sold it!
jamesearthdrum
Installed the 3rd speedometer today along with a new cable and drive. If it fails again I'm going to a bicycle computer  :dash2:
Also repaired a few cracks in the fairing.
peace:)james
~~~friederich nietzsche ~~~
higbonzo
I changed the oil and filter, installed new exhaust gaskets,  tighten chain, and installed new front and rear tires.  I was running the Pirelli Diablo Stradas',  which I was able to get over 10,000 miles on, and now I am running Pirelli Angels'.  The Angel is said to be an improved Strada.  I will post thought's of tire in the review section.
Later.....
jamesearthdrum
Finished up getting the fairing put back together. Fired up on the second try.  :good: Nice ride home, first since Dec. 4th.  :biggrin:
peace:)james
Mike 86 in San Dimas
My Corbin gunfighter arrived today.  :yahoo:  It's cool. Although a lower seat height, the width does get me more on my toes at a stop (just like I was warned). But being a munchkin, that's my life. I do like the feel on the road. Harder seat and feel a little more vibration than the stock saddle. Look forward to getting some highway miles on it. I bought it used from a post here and like the seller said, it was like new. Made the trip from Connecticut to So. Cal. in tact.
Mike
weymouth399
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
markmartin
Replaced the stock shock with a penske sport shock. Dissasembled the forks -- changed the bushings and fork seals and installed a set of race tech emulators--thanks to directions from the group. Waiting for a bottom half front fender and meter lens to come in from Zanottis before I can finish getting it all back together and try it out.
carsick
New front pilot power 2CT, EK chain and Pro grips. Taking some measurements for new dogbones. Of course after a week of sun it started snowing this morning, grrr.
markmartin
spray bombed motor and header pipes with hi-temp semigloss black.  In the process found that my gas tank was leaking at the fuel filter bracket where PO had JB welded a tear at the base of the bracket.   removed old jB weld and applied new JB weld.  attempted to replace fuel lines but had the wrong size OD fuel line. Torqued misc nuts and bolts while I've got the fairings off.
Bob
Replaced messy horn relay wiring.
Ordered new battery gauge to replace the one that died (only lasted four years).
http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/IMID/872
Replaced broken LED wiring; replaced H3 bulbs with LED bulbs.
Checked valve clearance.
Cleaned & polished all the shiny bits.
Cleaned very fussy brakes
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
yamahopper
I just picked up the seat from Seatmaster Upholstery. Absolutely beautiful! I'll post pics later. Got the Corbin seat recovered with alligator and smooth leather. Looks nice! Kirk is the best for custom seats in Louisville, KY. $150.00 and delivered on time. I don't know if I can post his phone number or not, but if you want information send me a P.M. and I will forward the address and phone number. He has a pattern for the Corbin seat and turn around is fairly fast. I also had some additional padding built in so the wife will quit complaining so much on the long ride.
Sometimes low and slow is the way to go.
