made a mistake
Started by groome, May 26, 2016, 12:42:16 PM
groome
hey all i made a mistake when ordering a new rear sprocket for the gsxr rear wheel i accidently ordered a 42 tooth instead of a 40 that i am currently running.  am i gonna be silly fitting it to see what its like or should i just return it and wait for a 40 tooth? o im running a 17 front sprocket. has anyone run this setup and what did they think?
cheers
89  fj12 banshee
Normal = BORING
I am sure others have run a 17/42 combo without problems. It is only a 5% difference in ratio. So your RPMs will be 5% higher to go the same speed as 17/40 combo. If you normally cruise at 4000 RPM then with the 42 you will be at 4200 RPM.
Pair that 42 rear with an 18 front.
groome
Quote from: FJmonkey on May 26, 2016, 12:52:50 PM
ah when you say it like that it doesnt sound too bad. i wasnt sure if it would make her want to spend alot of time on the back wheel as i tend to like 2 to the black stuff.
89  fj12 banshee
Normal = BORING
Quote from: FJ_Hooligan on May 26, 2016, 12:54:09 PM
Good idea, that will put the ratio nearly identical to the 17/40 combo and it is a little easier on the chain.
FYI 17-42 was the stock sprocket combo on my '84.
Quote from: Pat Conlon on May 26, 2016, 02:14:30 PM
But it had a larger rear tire than the GSXR wheel...
balky1
17-42 is stock combo for 84?
FJ 1100, 1985, sold
FJR 1300, 2009
TexasDave
17/42 gearing is stock fj84. I changed to 18/40 for lower highway cruising rpm.  Dave
4everFJ
In Europe, the stock gearing for 84/85 FJ1100 was 17/41.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
balky1
Quote from: 4everFJ on May 27, 2016, 02:22:36 AM
Aaaah, I know I read it somewhere so I was puzzled now for a moment. Thanks!
Ivan
FJ 1100, 1985, sold
FJR 1300, 2009
