Ii gotta chug now?
Started by Shane4371, May 22, 2016, 07:42:54 AM
Shane4371
Installed pilot jet 40,finally lifted my needle jet,now i gotta chug.surg at low speed not horri le but its thier,any ideas?
You changed two things, larger pilot jets and raised the needles. I doubt its the #40 jets and the needles are easy to put back where they were without removing the carbs. When trouble shooting, it is good to make only one change at a time. So try the needles back where they were and see if the "chug.surg" is affected.
I think you'll also need to adjust the idle mixture for the new pilots -- do that first since it will overlap with the other adjustment you are making
Shane4371
Very fat,can't I run them in.I'm at 3 turns out,
jscgdunn
Yes try turning them in at 1/2 turn incrments
90 FJ 1200 (Son # 2), Stock
Shane4371
Shane4371
I went 1/2 turn on each carb,rode it,no chug,then I went another 1/2 turn pinging on hard acceleration.going back 1/4 turn see what happens
