Simple oil change.
Started by Ognog, May 15, 2016, 04:51:54 PM
Ognog
I am getting a low oil light when I was low on gas and noticed its intermittent regardless I have opted to swap the filter and oil but can't seem to find a concrete anything saying what I'll need to do the job.
New 1986 FJ1200 owner as of 4/18.
Quote from: Ognog on May 15, 2016, 04:51:54 PM
.... regardless I have opted to swap the filter and oil but can't seem to find a concrete anything saying what I'll need to do the job.
Swap them with what?
I think you are asking about the low oil light. Does it come on during hard acceleration or going up hill?
Senior Simian, the hint is in the title of his post.
The second question remains the same. I stand corrected on the first.  :blush:
Ok, "swap the filter and oil..." meaning change your oil and filter...
In your 1986 FJ1200 Owners Handbook on 6-7 are step by step instructions (with pictures)  on how to change your oil and oil filter.
Lots of good stuff in the Owners Handbook.
Ognog
Quote from: Pat Conlon on May 15, 2016, 06:22:36 PM
That's exactly the question what size filter do I need and what oil should I use.
Ognog
Quote from: FJmonkey on May 15, 2016, 06:26:00 PM
No it's just on and then shuts off after a little while. Didn't come on consistently. Also I'll have to see if the fuel level may have affected it some how as I just went through my first take of gas and didn't see it early on.
Ognog
Quote from: Pat Conlon on May 15, 2016, 07:17:22 PM
20w40 on the oil but I did not see filter specs.
Shane4371
K/N401 is what I use on my 86fj1200
Shane4371
Quote from: Shane4371 on May 15, 2016, 08:01:50 PM
oil filter,fram filters are cheap.the k/ns are kinda pricey but it's worth it
Quote from: Ognog on May 15, 2016, 07:51:24 PM
You need a oil filter for a 1986 Yamaha FJ1200 (all years '84-'93 use the same filter)
copper
The filter is a canister you will several brand options but just one filter unless you change over to the rpm adapter
http://rpmracingca.com/proddetail.asp?prod=HF40
Then you can use spin on filters http://rpmracingca.com/proddetail.asp?prod=spinonfilteradapter
CutterBill
The OP's next question will be "How do I fix a stripped drain plug?"   :dash2:
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Ognog
Quote from: CutterBill on May 16, 2016, 07:08:18 AM
Haha I'll be sure to credit you in that posting lol
