Horrid mileage or normal?
Started by Ognog, May 15, 2016, 04:50:19 PM
Ognog
Just put my first tank of gas through the FJ and of course set the trip to a whopping 68.8 miles and refilled 4.2 gallons of gas for an exciting 16mpgs. Now I know this is twice the engine as my Versys but I don't feel half the gas mileage is right is it?
New 1986 FJ1200 owner as of 4/18.
Something is wildly amiss there.  Talking it easy, touring, fully loaded up...I'm in the mid-40 MPG range.  Riding at "Rally speeds", I will drop into the mid-30 MPG range.  16 MPG??!!
Brainstorming the possibilities:
Your calculator is broken.
Your odometer is broken
You left the engine idling in the garage overnight
You were in Canada and the 4.2 "Gallons" was really "Litres"
You're blowing raw fuel out the exhaust
You have a fuel leak
You're towing a travel trailer
Quote from: Capn Ron on May 15, 2016, 06:04:09 PM
You're towing a travel trailer - Full of bricks
That is about all I could add or fix. I also getting 40 average (actual) un-corrected because the ODO is off slightly then 45MPG.
Quote from: FJmonkey on May 15, 2016, 06:30:46 PM
You suffer from Dyslexia and 4.2 is really 2.4
I gave it my shot
Ognog
4.2 gallons was measured from the pump. I don't see any indications of a fuel leak or even fuel smell. And exhaust seems normal. It's very odd.
Shane4371
Check your oil level.has it risin.hope not.
Quote from: Shane4371 on May 15, 2016, 08:06:04 PM
His low oil light is coming on so his oil is not over full.
With a figure that far out of whack the first thing I would check is your calculation. Do it again on a subsequent tank of fuel before heading down any other path.
You say the amount of fuel was correct because it came straight out of the bowser, no doubt, but mpg is calculated on fuel used, not fuel replaced, you make no mention of how full the tank was to start with.
Recheck it making sure your tank is full before you start. If it's still lousy, then start investigating further.
Eliminate the obvious and easy stuff first.
Ognog
Quote from: ribbert on May 15, 2016, 08:55:02 PM
What an obvious answer lol. I filled it at a particularly low level but not quite dead empty and refilled around the same. I'll see on this upcoming tank and then get back. And I'll calculate the mileage with my phones gps as well.
balky1
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
FJ 1100, 1985, sold
FJR 1300, 2009
balky1
Mine burns 6.5 litres/100 km. I'm in no mood to convert this to MPG, sorry. Riding it hard, above 180 kph, fuel consumption rises to maximum 7.5 litres/100 km, two up and a lot of stuff on the bike.
Ivan
FJ 1100, 1985, sold
FJR 1300, 2009
mrnorm
Hi! 16mpg that is bad.
I just tuned up a 89 yamaha FJ 1200 I bought it this week. 50k miles on bike
I made sure it was tuned well and I mean the hole bike went for a 240 mile ride my mileage
corrected was 45 mpg all stock except for slipons on exhaust and that was in the cascade mountain range
here in Oregon speed was up and down 30-75 mostly I was driving as I always do on a good bike I wasent
hamering it just haveing fun. are you sure its running on all cylinders ? these bikes make good gas mileage
if every thing is right.  Brakes not draging, valves set right ?, tires with low air pressure, drive chain no good.
carbs messed up, what condition the bike is really in ? etc, etc,
Best Regards MRNORM
mrnorm
Using the GPS for mileage I get 45-49 mpg on 150 -250 mile trips.
Ognog
Looks like it was some fluke I'm not even half way through my second tank and at almost 60 now. We'll see what it ends up being.
