Clutch master cylinder
Started by Shane4371, May 13, 2016, 05:48:11 AM
Shane4371
Please advise,what year FJR will fit my 86?
4everFJ
I have used one from a 2001-2002 (RP04), so that definitely will fit.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
Shane4371
4everFJ
1978 - Yamaha SR500
wainot-Phil
I put a XJR1300  2004 Model  Brake and clutch master on my 85  fj1100
And
A  2010  model XJR1300  Brake and clutch Master cylinders on my 1994 FJ1200
fitted straight on...  and work great
""Past Bikes""
Suzuki Stinger 125
Honda 350/4
Kawasaki Z1000
Suzuki GS1000
Kawasaki GPZ900R
Yamaha FJ1100 84
Yamaha FJ1100 85
1990 FJ1200  Pinky
2006 FJR1300
1980 GS850
Z500 /4
XJR1300
"""Present Bikes""":
FJ1200  94
GSX1400
CutterBill
Quote from: Shane4371 on May 13, 2016, 05:48:11 AM
I'm just curious... why not simply use the stock master cylinder?  They are still available from Yamaha.
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Shane4371
All I seen was part obsolete for 86 fj,I rebuilt mine today.a little Emory cloth so far so good.
CutterBill
Quote from: Shane4371 on May 14, 2016, 08:54:49 PM
All I seen was part obsolete for 86 fj...
Interesting.  Checking the parts catalog shows that the clutch master for an '86 is indeed obsolete, but the master for a '92 is still available... $116.  I wonder what the difference is.  They both take the same rebuild kit.  Hmmm...
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Shane4371
Idk so I rebuilt mine,I replaced clutch,slave,now rebuilt master.fur will fit.if this rebuild don't last
Shane4371
CutterBill
ABS and non/ABS take the same clutch master.  I may have to dig my '85 clutch master out of the box and compare it to my '92 master.  Tomorrow; not tonight...
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Shane4371
Shane4371
I agree,don't over do it.seals will leak with heating from over packing.co workers and I disagree on bearings also.some use grease to prelude oil bathed bearings.I say no.grease has a resistance to move which can starve a bearing of its designed fluid ultimate bearing seizure.
Hemi Bob
I got a brand new Yamaha clutch master from Partzilla PN# 3BV-26450-10-00 for an 89 $115.00
Used it as a replacement on my 85. The bolts that hold the leaver on is  not available but Fastenal order me some for 2 bucks
The only mounting issue is the old one had a tab that keeps the master and the signal switch pod connected
a bit of black RTV sealant between the two and it fine .
Bob
Robert
1985 FJ1100  Original Owner
1986 FJ1200  X Drag Bike
1981 Suzuki GS 1100ex
1981 Suzuki GS 750ex
Shane4371
