Decal removal
Started by markmartin, May 09, 2016, 10:00:14 PM
markmartin
I've been contemplating removing the 'FJ' decals from the front fairing for a long time and finally decided to do it. Using a hair dryer and my finger nails and applying as much heat as my fingers could take, I was able to lift a corner up and then very slowly peel the decal off-- about a 10  minute operation/ decal.  I then used 'Goo-Gone' adhesive remover to slowly remove the remaining adhesive.  This was another tedious task.  It took a good 10 minutes of soaking the adhesive with remover before the adhesive would even begin to come off.  15 minutes of firm but careful scrubbing finally removed most of the adhesive. Lastly, I used some McGuiar's buffing compound and a buffer to remove the last of the residue.
Beautiful Mark! That's how a FJ should look, nothing to distract from those lines.
Goo Gone huh? And no problems with the paint finish...obviously.
I was just working on my room addition today and had the unpleasant experience of (red) tape adhesive on my aluminum window frames. The unmerciful sun over 3 weeks, baked the tape to aluminum.
I first tried WD40: not even close, mineral spirits: nope, lacquer thinner: no go.....I mean 'everything' comes off with lacquer thinner....that shit melts plastic.
I finally remembered my wife had a can of Goof Off under her sink. That worked like a charm.
However, I noticed reading the can and noticed that it contained acetone.
I thought to myself, I sure don't want to use this on a painted surface.
Well done laddie
Acetone is not aggressive on most automotive paint, but it will take the gloss off and if left on long enough will remove the paint.
Cool, can I try it on your bike?
Quote from: Pat Conlon on May 09, 2016, 10:50:44 PM
Sure, just keep it off the raw plastic and you get to polish the shine back.
moparman70
I believe GOO GONE is citrus based and wont harm anything but GOOF OFF --is more alcohol based or something like that and can harm paint and its recommended to try on a small area first.
sc2
I removed a couple of decals from the car paint (stupid PO) with this stuff and a lot of fingernail scraping... it worked okay.  Paint still looks shiny.  YMMV
http://tinyurl.com/hrydrew
markmartin
Good research guys. Moparman70, you're right on the money.
I happened to use 'Goo Gone' on the bike just by s**t luck because that's what I have at home.   I stock 'Goo Off' at work.  I considered these two products to be interchangeable, but preferred Goo Gone because it seemed to work better, and stock Goo Off at work because that's what my available vendor stocks.  Anyway-- I pulled up the SDS sheets on the products mentioned.  I'd stick with Goo Gone if I did it again. Turtle Wax Decal remover would be my second choice.  Goo Off sounds scary, but could probably double to free rusted machine threads. :)
Goo Gone
SECTION 3 – COMPOSITION / INFORMATION ON INGREDIENTS Chemical Name       Wt %
Petroleum distillates, hydrotreated light                                                              60-100 %
D-Limonene        1-5 %
Orange, sweet, extract        0.5-1.5 %
Goo Off
3. Composition/Information on Ingredients
Hazardous Components (Chemical Name)
1. Acetone                                                       60.0 %
2. Xylene (mixed isomers) {Benzene, dimethyl-} -             30.0 %
3. Ethylbenzene {Ethylbenzol; Phenylethane}                     5.0 %
4. Hydrotreated light distillate (petroleum)                             13.0 %
Diethylene glycol monobutyl ether                                1.0 -5.0 %
TURTLE WAX LABEL AND STICKER REMOVER
POSITION/INFORMATION ON INGREDIENTS
COMPONENT CAS NUMBER CONCENTRATION (wt %)
Diethylene Glycol Nonobutyl Ether              20-30%
(Glycol ether DB)
Petroleum Distilate                            30-40%
(Hydrotreated Light Distillate Solvent)
Propane                                       10-15%
(Liquified Petroleum Gas)
Acetone                                       10-15%
(2-Propanone)
d-Limonene                               5-8%
(Orange Turtpenes)
weymouth399
Mark you get that gas tank painted yet? If I can ride this yr? We should get together and do a Bangor east ride.
Bob w
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
markmartin
Quote from: weymouth399 on May 10, 2016, 07:37:59 AM
Bob w
I sure did Bob, and fired it up last night. The tank looks great. http://www.fjowners.com/index.php?topic=15342.msg156152#msg156152
Text me when you're ready - I'm up for any ride - The Owls Head / Tenants Harbor area might be a good half way point for both of us.
