looking for right front turn sig lens, 1989 FJ1200 in Ct please
Started by Keith, April 19, 2016, 08:45:42 PM
Keith
On my way home from work I noticed a missing piece....yes my orange colored right front turn signal lens on my 1989 FJ 1200, does anyone here have one for sale?, Thank you Keith
Kookaloo?!?
1974 Honda CB360T cafe bike,1975 Kawasaki S3 400cc 2stroke triple,
2008 Yamaha WR250R,198?Honda125M3wheeler
1989 YAMAHA FJ1200,
Quote from: Keith on April 19, 2016, 08:45:42 PM
Have you checked the mounting tabs, I recently re-welded my RH tab. I took the lens off and a piece fell to the garage floor. Crap!  :dash2: I just had the fairing off.
Here is the piece with the U-nut for the screw to secure the lens.
This tab is too thin and will likely brake again, or just melt away if I try to weld it back on.
So I grind the ribs down to allow a flat piece to tie in the inside of the fairing to the ribs with some homemade ABS putty. I gouge out the gap (old soldering iron) to allow a weld bead to secure the piece.
Then weld it to the fairing and signal tab.
A little more sanding to clean up and Weld on the mounting tab.
A little more clean up and match drill the hole to complete the job. Stronger than new.
My cool smoke turn signal lenses from Avationfred.
Maybe Avationfred can share his source for the '89 lenses.
The 1988-1990 front signal lenses are very difficult to find. Have a look here at Poway motorcycles. I have purchased from them on a number of occasions. The owner was a long time FJ owner and carries a large stock of used FJ parts.
http://powaymotorcycle.com/SanDiego/
In box #18 there are a set of signal lenses. It may be worth a call to verify if these are for the '88-'90 models. My bet is that these are for the '91-'93 models.
https://picasaweb.google.com/114333149059306462902/UsedParts?authkey=Gv1sRgCPrL0bzw-deBlgE&feat=flashalbum#5400387649614680962
I also found what looks like a NOS front Right lens on eBay France. Shipping to the US is just under 5 Euros.
http://www.ebay.fr/itm/YAMAHA-FJ-1200-3CV-89-90-BLINKERGLAS-VORNE-LINKS-LENS-FLASHER-FRONT-RIGH-/222077130434?hash=item33b4d416c2:g:lWAAAOSwT6pV5ELV
If you want something different and can handle the steep price. I have a spare set of CLEAR front signal lenses. Price is what I paid. $95.00
Keith
Kookaloo?!?
1989 YAMAHA FJ1200,
jyrki
Hi, I lost my right turn signal cover while riding... You have a clear set of those for my model 1988 FJ1200?
Br Jyrki
Quote from: jyrki on May 17, 2016, 10:37:42 AM
Br Jyrki
I have a clear set available for the 1988-1990 3CV models. These will not fit the 1TX or 3XW models.
Here is a photo of the lenses installed.
Keith
Thanks to Weymouth399 of this forum...... I got the lens last week, and found it to be OK for the money, I am happy Thank you Sir!
Kookaloo?!?
1989 YAMAHA FJ1200,
