Ultrasonic parts cleaner
Started by twangin4u, April 15, 2016, 02:26:35 PM
Quote from: FJools on April 18, 2016, 05:15:06 PM
How long in the cleaner and at what temperature for carbs?
Thats something that I found little info on.............
Time varies by the condition of the carbs.
I have never checked the temp of my cleaner, but I know you can't hold the parts when they come out with bare hands.
jscgdunn
Even without heat it they work well.  The element on our cheapy burned out pretty quickly but it still works...just take longer.  About two hours.  The ultrasonic action actually warms the water up quite a bit.
90 FJ 1200 (Son # 2), Stock
JMR
 Have any of you fellas tried a solution of the Yamaha carb cleaner in the sonic cleaner? I have had very good luck with the carb cleaner over the past 20 years but I haven't used it in the sonic cleaner tank. I haven't found it to mess up the exterior either.
Quote from: jscgdunn on April 19, 2016, 09:05:36 AM
Well, since I have a 2.5 gallon cleaner it would take forever to generate any heat via the ultrasonic motion.
Also, the Crest soap requires heat to work properly.
Operating Conditions
Chem-Crest 235 is typically used at 5 - 10% by volume in
ultrasonic applications. Normal operating temperatures:
120 - 180°F, dependent on the material makeup of the
substrate, and the contaminants being removed.
Contact your Crest representative for product-line
specific recommendations. Recommended rinsing water
temperature: 120 - 150°F.
I have heard of all kinds of concoctions people use in their cleaners from Ammonia to Simple Green to lye based drain cleaners.
I use the cleaning solution based on the proper application of the carb material I am working on. I cannot chance damaging a single carb.
jscgdunn
Quote from: racerrad8 on April 19, 2016, 10:35:32 AM
Yes wish ours still heated.....again, I just use Sunlight soap...would much prefer the product above.
