Can't get the swingarm out..!!
Started by 4everFJ, April 12, 2016, 02:05:19 PM
4everFJ
Any tricks to get the fracking swingarm out!!?
Shaft and everything is removed without problems and it pivots freely up and down, but I simply can't pull it out  :mad:
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
jscgdunn
use a rubber hammer and tap it out
90 FJ 1200 (Son # 2), Stock
4everFJ
There isn't really any space to get a hammer in and tap it in the right direction/place.
1978 - Yamaha SR500
If I remember correctly you have to tilt the swing arm up a bit and pull to the rear of the bike.
4everFJ
Thanks, but I have tried every angle possible..
Would it perhaps help to loosen the lower engine mount?
1978 - Yamaha SR500
Lift the arm up at the pivot point, then pull back.
4everFJ
Quote from: Pat Conlon on April 12, 2016, 02:57:05 PM
Not sure I understand what you mean? Lift it with a jack at the pivot point, or..?
1978 - Yamaha SR500
Has the arm moved from the pivot point at all?
4everFJ
Quote from: FJmonkey on April 12, 2016, 03:12:05 PM
Yes, maybe a hair or two..
1978 - Yamaha SR500
jscgdunn
Quote from: 4everFJ on April 12, 2016, 02:15:22 PM
Could you send some pics of the bolt you removed and the situation?
4everFJ
Quote from: jscgdunn on April 12, 2016, 03:25:13 PM
Yes, but not sure what you want to see?
There is only one bolt holding the swingarm and it has been removed (I can see through the hole where it used to be  :smile: ).
Other than that, it would just be a picture of the swingarm sitting in the frame.
1978 - Yamaha SR500
paulfj03
Try pushing the swing arm towards the front of the bike, then up , then pull it back out. ...
For some reason i remember having to do that.
If the '84/'85 frame is like the '86 frame then you need knock the pivot point up and slightly rearward. See the hollow area just above the pivot point. The first time I took my swing arm out it was harder than the times after that. Maybe you can get a lever to pry it gently on each side till it breaks free.
ct7088
I had to loosen both footrest brackets to remove the swingarm.
Chris
Chris
Quote from: 4everFJ on April 12, 2016, 02:27:56 PM
Yes - and you can pry the swingarm up and back easier than using a mallet.
