No brake light
Started by Shane4371, March 29, 2016, 07:07:58 PM
Quote from: Shane4371 on March 29, 2016, 08:52:53 PM
Black,why?
Red shows how dirty they are... Black means clean them as often as the Red ones. You just know from the color.... :blum1:
Shane4371
I'm thinking clean them with every oil change?
Shane4371
Sounds crazy,i've got 3 in 401 oil filters and 12 quarts of 20w50 castroll oil,that's to be all used up by August this year,
Shane4371
Quote from: Shane4371 on March 29, 2016, 09:10:22 PM
weather it needs it or not
Quote from: Shane4371 on March 29, 2016, 09:07:18 PM
Works good every oil change, wait till you see the crud that flushes out when you wash them. I use dish soap and very hot water, twice. Then a good dry off period. Fans help speed that up if you need to ride,,,
Quote from: Shane4371 on March 29, 2016, 07:49:41 PM
Quote from: Shane4371 on March 29, 2016, 07:46:28 PM
I got uni pods from rpm today,didn't know the oil you gotta apply to them was a separate lurch item.kinda kissed me off
in the item description it doesn't say the oil needs to be lurched separate
The description has been changed so no one else make the assumption that the filter oil or cleaner is included with the purchase of the air filter.
Quote from: Shane4371 on March 29, 2016, 07:32:36 PM
I asked them if it would work with my 86
I replied to your email this morning. I do not have the stock brake light switch in stock, I have a call into my Yamaha supplier for pricing to get you one.
The brake light switch I sell on the website is the conversion switch for the FJR master cylinder when adding it to the FJ. Since the FJR is ABS they use a switch that functions opposite of the stock FJ switch.
I will let you know via email about the stock brake light switch.
Shane4371
Thanks for the outstanding service,we hatched it out.I'll be worry free in a few day,
