massive overfueling
Started by LimiterBash, March 05, 2016, 02:47:31 AM
LimiterBash
Hi all,
I recently had a spark problem and thanks to a member of this forum I have determined it was my Dyna 2000. I have just purchased a new one off ebay. My new problem is when it started running fuel was flowing extremely heavily out of the overflow lines. So Im guessing its a seal or something in the carbys but as I dont know a lot about these I thought I would ask the question. What should I do? Pull them a part?
Urban_Legend
It is usually a float or needle and seat issue with fuel that comes out the overflows. They could be stuck in the open position.  First try giving the float bowls at tap to see if it fixes the issue.  If it continues you might have some crud in them. If the bike hasn't run in a while the carbs probably need a.good (as in completely stripping) clean.
Mark
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
Bones
Yes. To avoid further problems later on, pull them apart and go right through them making sure everything is spotlessly clean and in spec. Check diaphragms have no holes in them, get the SS screw kit from Randy that has all the o rings and Allen screws in it and replace everything, check the float tongue where the needle sits isn't pitted and that the levels are correct, make sure the emulsion tubes are clean and are not worn oval and check that the air filter/s is clean.
Basically, do a thorough job the first time and you won't have to worry about pulling the carbs off constantly like a lot of people do to fix minor problems.
93 fj1200
79 suzuki gt250x7
Alf
Hi
Probably any of the fuel float bowls is blocked in its movement, leave the fuel float valve open and then the carb overflows. Usually It could happen when the bike is without working 1 week or more
There are 2 easy ways to solve that usually works:
1.- With a spanner and a hammer give a series of not too hard bumps to the carb float bowls caps. The trapped float bowl is released
2.- If the previous way don't work, ride the bike, let the engine get temperature and perform 2,3,4 times full throttle accelerations until the red line
Usually this treatment works. In fact, my CBX had the same problem yesterday. I knew a fuel float bowl was blocked because the bike overflowed when the engine was stooped and the fuel key was open and when the engine was running the bike was perfectly from 5.000 rpm and only in 3 cylinder when below
4 times accelerating from 3 to 6 until the redline and the problem was solved
oldktmdude
   When you get the carbies apart, replace the "o" rings that seal the needle valve seats that control the fuel flow into the bowls. These "o" rings harden and become brittle over time and will cause the problem that you are experiencing. Go to the "Files" section and read the carbie cleaning write-up thoroughly, most people DON'T get them clean the first attempt, so do yourself a favour and read it carefully and get it right the first time.  Pay special attention to cleaning the choke circuit passages in the float bowel housings. If these are blocked you will have a difficult time starting the engine. Good luck!
Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
