1986 fj1200 tear down
Started by Bandit650, March 03, 2016, 04:43:33 AM
Bandit650
Spent a while yesterday pushing out bearings got them all out without too much trouble but then came the swing arm bearings.
Knocked out the needles and internals with a drift which just left the bearing casing in the swingarm.
Went on to the forum and Internet looking for easiest solution. I think the post about heating the area sounded the easiest to me . Went back out to the shed but my blowtorch was empty.
It's then I thought of the welder. It's a diy stick welder and I can weld two things together sufficiently but it's never pretty.
I put two lumps of weld opposite each other inside the bearing casings and used the heat generated to nicely push out the casing with a socket and extension that just fitted into the shaft but not past the welds.
Couldn't believe how nicely they pushed out using a home made press that I bought recently .
Very good Bandito!  :good2:
Several FJ folks have reported using this same technique to remove the (pesky) lower race of the steering stem bearings.
Bandit650
I tackled the rear master cylinder which was siezed tight. Drilled a pilot hole in the plunger and drove in a 100mm screw. Tapped the end of the screw with a hammer to get the plunger moving which it did and then yanked on the screw with the claws of the hammer to drag it out. "Voila" job done left with a perfectly serviceable part awaiting rebuild kit.[/URL[URL=http://s1073.photobucket.com/user/stephen_kelly3/media/Mobile%20Uploads/2016-03/31B8057B-A9BB-419A-AAD6-6456193A1451_zpsvwi0ivjv.jpg.html]
Bandit650
Update... Waiting for frame and wheels to come back from powdercoat and polish ,cleaned up some body parts. It's hard to believe this is all original paint , there is 60000 miles on this bike it's a testament to the quality of the original build.
Awesome, I am dying to rebuild my '86 and get her back on the road. This is not helping, keep up the good work.  :good2:
Bandit650
Out with the old in with the new.
Picked up this cbr600 F4i Shock this morning at a bike breakers in Dublin.
Full working guarantee and they were having a 20% sale today only ,got it for €60 ($70).
HAPPY DAYS!!!
