1993 FJ1200 ABS Carbs most likely gummed up - Tips -Seafoam? jet cleaning?
Started by rick9141965, November 16, 2015, 08:18:56 AM
rick9141965
Picked up extremely clean 93 FJ that has most likely sat to long with old gas. Will start and stay running with choke on only....Even with choke on and idling the idle will rev up and down on its own. Even riding it choke must be pulled out Once you get up to 20mph I can turn choke off and it rides OK but once the RPM's are low the bike will die.. What do you guys think of Seafoam? If I pull the tank, drain gas  put some Seafoam in there and let it sit for 24 hours or longer.. Will the stuff really clean out the plugged Idle jets? it has 29k on the clock
FJ1100mjk
Quote from: rick9141965 on November 16, 2015, 08:18:56 AM
Picked up extremely clean 93 FJ that has most likely sat to long with old gas. What do you guys think of Seafoam? If I pull the tank, drain gas  put some Seafoam in there and let it sit for 24 hours or longer.. Will the stuff really clean out the plugged Idle jets?
Probably not. You'll need to got through the FJ Ownership Rite of Passage...
Removal of the carbs, disassembly of them, thoroughly clean them, renew what is necessary in them, set the fuel level in their float bowls, bench synch them, have fun {sarcasm added} reinstalling them back on the bike, set your valve clearances, warm the bike up, adjust the air screws, and then final synch the carbs with a Morgan Carbtune or similar tool.
After you do the above, you are good to go for a long time.
Iron Balls #00002175
www.ironballs.com
rick9141965
I agree.. No miracle in a bottle!! I have a Motorcycle mechanic that quoted me $250 USD for labor plus part$ to clean them and all the other necessary syncing. Had to spend it but prob cost me more if I attempt that myself!
Flynt
Quote from: rick9141965 on November 16, 2015, 08:48:59 AM
Look into sending to RPM...  they'll rebuild, bench synch, and return to you ready to bolt on and ride (by most reports).  You'll still need to check and probably adjust valve clearances, but there is no better option for your carbs.
Quote from: Flynt on November 16, 2015, 08:55:13 AM
Just an FYI...The current labor charge for RPM carb rebuilding is $160.00. The only mandatory parts required for the rebuild is the S/S screw & o-ring kit as the carbs are completely broken down and ultrasonic cleaned. If other additional parts or jetting is required that is an additional cost.
We can usually turn the carbs around in two days or less.
When you get them back, you need to drain the tank, replace the fuel filter, flush the fuel pump with new fuel, install the carbs and head off for a ride. They are ready to go when you get them back.
Let us know if we can be of assistance.
randy@rpmracingca.com
209-844-9831
+1  :good2:
If Randy can't fix 'em, they're total junk... and his prices are quite reasonable, IMO.
http://www.fjowners.com/index.php?topic=10053.0
Quote from: racerrad8 on November 16, 2015, 12:28:18 PM
209-844-9831
Still one Hell of a deal!
rick9141965
If I pull the carbs off and take the bowls off and just clean the jets and what ever else is in there will I have to sync the carbs when I put it back on or will it fire up like prior to pulling carbs?
FJ1100mjk
Quote from: rick9141965 on November 18, 2015, 06:06:42 AM
You don't have to synch the carbs, but you're shortchanging yourself if you don't. Synching will smooth the idle, and help with just-off idle throttle response.
If your bike sat for a while, the passageways in the carb bodies that carry the fuel to various circuits could be plugged or restricted too, so "just" cleaning the jets will net you little return on your efforts.
Use the Google search engine to find good carb cleaning and rebuild posts, that have pics and good descriptions. Make sure to include the word FJowners.com in the search too. There's good info to be found that way for not only carb problems, but many other common FJ maladies that have been covered in detail over the years.
www.ironballs.com
I think the Yamaha service manual spec's to sync the carbs annually.  Probably over kill but it indicates how important they think it is to a good running FJ.
IMO anyone that owns an FJ should have a sync tool. You can make one for less than 10-20.00 that works as good as any on the market. It is super easy to do. On any multiple cylinder motorcycle you will be glad to have a sync tool around.
rick9141965
is there any easy way to drain the gas from the carburetor bowls? Besides starting it?
Open the drain screws on the bottom of bowls.
Have you read the carb Files?
rick9141965
Can u get to the drain screws easily while carbs are still mounted on the bike?
Yes, the bowls can be drained in place. Use the biggest flat head screw driver that will fit and use plenty of pressure to keep it from messing up the head... My '86 is bone dry and waiting a rebuild.
Quote from: rick9141965 on November 18, 2015, 09:33:40 PM
Yes, If the bowls were installed correctly.
Even still if you want, you can remove the carbs, then drain the gas. It's no big deal to remove the carbs with fuel in the bowls.
