Why Do We Use Brake Fluid?
Started by CutterBill, November 15, 2015, 09:02:13 PM
FJ Flyer
Replaced the clutch slave cylinder around 1999.  That was the only time I had an issue in 118K miles.  Still using DOT 4.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
CutterBill
How often do you flush the fluid?
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Earl Svorks
As I recall, from theory in trade school (long ago,1970's) one of the several qualities required of brake fluid is a low and stable viscosity.
The glycol based fluids , being much like antifreeze remain fairly thin even at low ambient temperatures. A brake whose feel and performance might vary with seasonal temperatures, or even from morning to night temps. seems like a bad idea.
fjfool
i agree with the OP but even take it farther
why would i want ANY plumbing on the bike where it is not needed
all my bikes with cable actuated clutches do just fine, including the 2016
temperatures are out of the equation
i would prefer a modification that did away with the silly fluid clutch and replaced it with a cable
CutterBill
Quote from: fjfool on November 20, 2015, 07:15:52 AM
Cable controls have more friction than hydraulic controls.  Might make for a stiff clutch lever.  But ignoring that, what would you suggest about the brakes?  Go back to cable, like my old Honda CL350 with drum brakes?  No thanks...
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
fjfool
mmm, dont remember referring to the brakes in my post, i was talking about the clutch and the bullshit hydraulic system
ya know, 'cause cable clutches dont perform well
fjfool
i guess Josh wouldnt know a proper clutch setup for his bike because it uses a cable
FJ Flyer
Quote from: CutterBill on November 19, 2015, 11:28:09 PM
Sadly, only a couple times.  Put on stainless lines.  It was my daily rider for almost 10 years.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
