Fuel leaked in the crankcase
Started by balky1, August 18, 2015, 01:31:20 PM
Quote from: balky1 on August 20, 2015, 05:48:00 AM
Yep, probably.
Thx Noel. All sort of things come to my mind also right now. :-)
No, pushing it off a cliff wasn't what I had in mind  :biggrin:
balky1
Quote from: ribbert on August 20, 2015, 07:04:34 AM
Yep, probably.
:rofl2:
FJ 1100, 1985, sold
FJR 1300, 2009
There are all kinds of fuel petcock replacement screens available.
Get something like this--->http://www.jpcycles.com/product/720-097
Get some sort of fuel resistant epoxy, and glue it to your petcock.
Like Noel said, just go to a "Powersports" type shop or dealer. I'm sure they have a number of different screens behind the counter.
jscgdunn
Quote from: FJmonkey on August 20, 2015, 03:35:33 AM
Quote from: balky1 on August 20, 2015, 02:04:16 AM
Yeah, but how to fix it when I can't find it anywhere. Except to buy the whole petcock and right now not enough money for such thing. That filter is on my priority list for long time, since I've seen it has been tampered with, but couldn't find it anywhere. In-line filter is out of the question because of starvation probs, as I've read it here.
I was also surprised that without the filter I've still ridden the bike 15000 km witout any problems. That would mean that either the fuel tank and fuel were very clean (lol, not obviously :-D) or that I was one lucky SOB not to get any of the jets clogged.
I see, a difficult situation to stay running on a budget. Perhaps some other members here can find some options that will help. I will will keep looking, you are not the only one looking for a filter unit to fit an '84/'85.
[edit] I just found something and sent you a PM
Re: Starvation Problems: I can tell you that we have a wix inline (from Randy) on our 86 because of the tank and it has no starvation issues except possibly at very high rpms for an extended period.  In normal riding there are no issues at all.
Jeff
90 FJ 1200 (Son # 2), Stock
Quote from: balky1 on August 20, 2015, 05:44:07 AM
.......coarser filter should, by my logic also, work fine.......
The idea of the screen at the source is also to keep crap out of the petcock. An in-line filter that free flowing would not be considered by most to be a filter. I'm not even sure cheap in line filters offer degrees of filtration.
jscgdunn
Boy Noel, you are a nighthawk.  :mail1:
AppleJack
I've recently been dealing with this same issue.  All the fine mesh screen material missing from petcock inlet.
I got some metal window screen material and JB Weld intended for gas tank repair and simply "JB'd" it in place.  Obviously much larger openings but, I believe, better than nothing.
http://www.travers.com/81-007-303?Category=UserSearch=81-007-303&gclid=CK2AtJfjwccCFYc6gQodP80AcA
Haven't totally finished carbs rebuild yet, so will report back when ready to ride!
Good luck with it...
Jon Appleby
balky1
Quote from: AppleJack on August 24, 2015, 08:06:45 AM
I got the carbs down. Float was set high in carb 2 from which it leaks. I hoped that is the problem, set all floats to 23 mm, but leaks still. So I ordered new float valve and seat to get rid of the problems. But I will have to wait for it until monday. Meanwhile no riding.  :gamer:
Petcock screen repair still in progress. I will report the success (or failure  :bomb:).
FJ 1100, 1985, sold
FJR 1300, 2009
FJ1100mjk
Just a word of warning, but depending on what JB Weld that you used, some are only classed as "resistant" to gasoline, and may not fare too well if submersed in gasoline.
See sixth FAQ down...
http://www.jbweld.com/pages/faqs
Iron Balls #00002175
www.ironballs.com
Quote from: balky1 on August 24, 2015, 08:17:37 AM
I hoped that is the problem, set all floats to 23 mm, but leaks still. So I ordered new float valve and seat to get rid of the problems.....
Did you Replace all of your float needle seat o rings?  You need to, they dry out, loose their seals and leak.
balky1
Quote from: Pat Conlon on August 24, 2015, 11:34:39 AM
Well... No.
FJ 1100, 1985, sold
FJR 1300, 2009
AppleJack
MJK - Yes, I made certain that the product was compatible for gasoline.  Says so right on the packaging -
"Will cure submerged in water or gasoline"
Thanks...
Jon Appleby
Quote from: AppleJack on August 24, 2015, 07:47:15 PM
Thanks...
That open mesh is like nothing at all.
Flynt
Quote from: FJmonkey on August 24, 2015, 08:01:59 PM
Thanks...
+1.  Make a little sock out of a fine mesh and put it on over the corse one you have there.  Now you've got a fine mesh with a strong structure to support it AND a nice little bag to capture the JBW chunks if it goes to shit.  Great plan!
balky1
Thanks...
It is coarse for sure, but if you saw the chunk that got stuck in my petcock.... Even with such mesh, it wouldn't.
Just as an info for you all. Sieve makers usually sell stainless steel mesh also. With various apertures. If anyone need it. Tyler is the manufacturer in USA, in EU there are many: Retsch and Endecotts for example.
FJ 1100, 1985, sold
FJR 1300, 2009
