How much play in Rear suspension is OK?
Started by biggo, August 14, 2015, 08:08:30 PM
biggo
Hi All.
Have stripped cleaned and re-greased all my rear suspension linkages and bearing. Very slight tarnishing on bushes that run inside roller bearings but no visible wear.
We everything reassembled and rear wheel off the ground if I put a lever between bottom of rear tyre and the floor I can lift the wheel about 2-3 mm before any resistance from the shock. i.e There is a small amount of play so really after some thoughts on what might be considered acceptable.
Thanks  Phil
FJ1200 1994
XJ900F 1986
http://biggsbiking.blogspot.co.nz/
mr blackstock
G day,
I reckon the amount of play you have is fine. There are exact figures in the manual but if you dont have one to check
Don't stress too much until your clearances increase
Cheers, gareth
Yamaha FJ1100 1985
As long as the side to side play is minimal ,you are ok.
biggo
Thanks for the feedback I think I will just monitor it maybe get new bearings next time I strip and clean them
Cheers  Phil
FJ1200 1994
XJ900F 1986
CutterBill
If you have play in the suspension, that means something is worn out or loose.  If it were me, I would find it and fix it.
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
mr blackstock
G'day,
I am pretty sure that when I looked in the manual about suspension awhile ago, a small amount of play was allowable, considering the leverage in relation to the length of the swingarm I would be pretty surprised if there was no play.
Biggo, In relation to buying suspension parts, go through part shark out of the U.S, much cheaper than the local suppliers.  When I revamped my suspension the cost difference was huge!
cheers, Gareth
Yamaha FJ1100 1985
