head gaskets
Started by theLeopard, August 09, 2015, 11:27:05 AM
theLeopard
anyone have experience with head gaskets.
i guess i blew one (or more) of mine.
engine expells compression from some unidentified location and misfires.
occassionally dies at 1000rpm idle.
gonna read thru my manual but tips & advice are always welcomed.
1992 FJ1200
theLeopard
im browsing thru my manual.
only head gasket i can find is the valve cover gasket and i aoready replaced that.
am i missing something?
1992 FJ1200
Quote from: theLeopard on August 09, 2015, 12:40:31 PM
Is item 5 what you are looking for?
http://www.ronayers.com/oemparts/a/yam/50043271f8700209bc78b2cb/cylinder
Or item 18?
http://www.ronayers.com/oemparts/a/yam/50043271f8700209bc78b2ca/cylinder-head
Either one can be sourced from Randy at RPM quite quickly if needed fast. Plus he will have good prices and can supply all the other bits you will need for this job.
theLeopard
randy has the gasket. not sure why i havent found it in my manual yet but its the aluminum gasket for the heads not the valves
ooc does randys carb rebuild kit have stock jets or the recommended (larger) jets?
110/42.5/155
https://www.rpmracingca.com/proddetail.asp?prod=Carb%3Arebuildkit3&cat=39
1992 FJ1200
My knowledge of the head gasket is limited to the one time I pulled the FJ head but to add to the knowledge base when shopping for a FJ 1200 head gasket you can run across 2 different Yamaha versions.  The picture below shows the difference.  The top one is the newer style and the one you probably want. RPM sells the newer version I am sure.  The older version you will see on e bay and resellers of discontinued parts so heads up.
If you do the job you will need a couple of special copper washers and seals also.
Your comment on  "engine expells compression from some unidentified location" could also be a valve.
Quote from: theLeopard on August 09, 2015, 01:08:46 PM
110/42.5/155
I am sure you can request what jet sizes you want, and Randy can make recommendations once he knows more about your bike.
theLeopard
ugh.
i wanted to rebuild the engine looks like i may get my wish :dash2:
found the gasket in the book, 3-46.
I'll pick up the engine gasket kit also,  trying to fix an oil drip maybe ill get lucky.
1992 FJ1200
theLeopard
while were on the subject when i decelerate via compression i occassionally hear this sound which i can only describe as jingling keys.
1992 FJ1200
Steve_in_Florida
Quote from: theLeopard on August 09, 2015, 01:27:46 PM
I have to ask: Have you accounted for all your keys?
Steve  :pardon:
`90 FJ-1200
`92 FJ-1200
IBA # 54823
