New Gauges
Started by Urban_Legend, August 07, 2015, 07:25:41 AM
Urban_Legend
Hooray,  My new gauges have turned up from speed hut. Will put full install info in my project page, but had to share. (my kids tell me "sharing is caring ")
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
They look great.... :good2:
great white
Looks nice.
Couple questions if you don't mind.
I see the clock buttons are not in the cluster. Do you loose the clock?
Does it work wit the stock Yamaha wiring to cancel the turn signals? IE: does it have the reed switch or do you have to rely on the 10 sec timer to cancel the sigs?
Is the speedo cable or GPS driven?
I believe Mark has a 1100, so there is no clock on that model.
Very nice Mark!  Any surprises on the install?
oz.fj
That looks great Mark... Thanks for caring.
89 FJ 1200 Shiny Black
89 FJ 1200 x 3 Red White Silver
92 XR 250
Life is pretty straight without twisties
Urban_Legend
Hey Great White.
My new gauges are mounted into an old spare cluster that that I had from an FJ1200. The clock didn't work in this cluster anyway (who care what time it is when you are riding, except if it is beer o'clock) and the speedo had already been pillage for my current cluster after the original speedo failed. (the current one is not working either now) I have never been a fan of the auto cancel on the FJ (always turns off before I want it too) so not a concern for me. I am used to riding bike without this feature anyway.
I hope to get them fitted this weekend, but lots to do on the bike so may not happen. I am also hopefully adding my GSXR rear wheel this weekend. As I said I said lots to do.
Mark
Mark
My Baby (Sparkles)
Sabre093
Did you send the cluster to them....how much they charge ya?
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
Urban_Legend
Quote from: Sabre093 on August 07, 2015, 06:33:04 PM
No, they sent them to me packaged individually. (matched set though) and I fitted to my dash last night. I managed to fit them without having to grind off the grip lugs on the clamp rings (unsure of that they actually called. The spin on ring that screws on the back of the gauge, the clamps it into place in the dash) as another member on this forum had to do. Basically I held the ring in place and spun the gauge, until it was a firm fit.
Mark
Mark
My Baby (Sparkles)
Country Joe
Those gauges look stellar!! :good2:
1993 FJ 1200
Flynt
Beautiful job...
Urban_Legend
Sorry forgot to mention, the full set of 3 gauges (in Aussie Dollars) cot me about $600 including international postage. In the USA you could probably get them all for $450. I think their prices a very reasonable. I you went for Autometer or VDO gauges it would cost you a lot more, and you can customise the speedhut gauges for colour, font style lighting colour etc. I had them add an indicated red line on the tacho and they set my Odometer to 36000km to match my old speedo (which is wrong anyway)
Mark
My Baby (Sparkles)
Question Mark: Are you going to be able to push the reset button once you put the clear cover over the cluster? Looks short.
I am interested if the FJ's fuel tank float sender plays nice with the Speed Hut gauge.
Urban_Legend
Quote from: Pat Conlon on August 07, 2015, 10:48:06 PM
Hi Pat. Not sure about the reset button, will find out in due time. The remote switch had a reasonable length lead, so I may be able to attach it directly to the clear cluster cover. The fuel gauge has an adjustable Ohm range so I am hoping it will play nice. The Tacho can be set for pretty much engine configuration (1 cylinder through to V8)
Mark
Mark
My Baby (Sparkles)
When doing the set up for the tachometer, factor in that the FJ is a wasted spark engine design. The tachometer only receives half of the pulses of a regular 4 cylinder. I found this out when doing my digital tachometer mod.
