Cam chain tensioner
Started by twangin4u, June 20, 2015, 10:57:26 PM
twangin4u
Are there signs that can chain tensioner should be replaced?
bigbore2
Any good mechanic can just listen to the engine running and hear if the chains are looser than they should be.
If you had another FJ bike to compare to, you could do it yourself.
Pull the valve cover see if you can detect any slop in the chain then check the cam timing.
Next use a wrench on the cam hex and see it you can pull any slack in the chain.
copper
Quote from: twangin4u on June 20, 2015, 10:57:26 PM
Stop by and see Randy at RPM...see what he thinks
twangin4u
