Soft clutch
Started by ahdblo7, June 04, 2015, 07:32:08 PM
ahdblo7
Ok I have through the clutch section and have partially determined my problem but now don't know what to do I replaced all the clutch plates but when I took everything apart I made the mistake of touching the clutch lever and pushed the rod out when I reassembled everything yes it was hard. I took everything apart I took the 3 screws out the other side of the bike pushed the piece back in sorry I don't know the names of the part put the clutch plates everything back on to specific torque settings and now it is soft it appears that the slave bleed nut is not staying in position or there is insufficient pressure on it. what next guys
ahdblo7
okay so I took everything apart again I took the slave cylinder off and inserted slave bleed nut but when I put the cylinder back on the other side it pushes the slave bleed not back out again what am I doing wrong.
I don't know if I am reading this right, are you saying the clutch slave bleed valve is not staying screwed in? Do you have pressure at the clutch lever? So you have the clutch slave pushrod back in position, the clutch slave is bolted back on with the 3 bolts. If that is right and you have no fluid dribbling out from the bleed valve, I would bleed the clutch line properley and you should have pressure back with a working clutch.
