rpm dualpods
Started by JOMPPA10, May 30, 2015, 10:26:46 AM
JOMPPA10
Ihave guestion: how i can fit pods in place? tried seweral times when i thigh band it pop off
ewerything cleaned with brake cleaner and i supposed there not oil?
copper
Oil the filter element. Clean both mounting surfaces with brake or carb clean. I push the base of the pod with one hand and tighten with the other. If you tighten too tight they will pop off. I snug down on them give them a tug when I think they are just right enough and they always stay.
IceFJ
I had the same problem when I installed dual pods last year, my experience is that there is a thin film of silicone or something of that sort on the rubber part of the new pods, I used some solvent to clean it off and then everything was good.
I agree that the torque is low otherwise it may "press" the pods off.
Magnus
Yamaha FJ1200 `86 (current)
Honda XR400R `00 (current)
Kawasaki GPZ550 `82
Horex 350 `52
Jawa 350
Honda XL500 `82
Honda XL500 `80
Honda SS50 `75
