1100 head gasket source?
Started by indyblue, May 20, 2015, 12:22:56 PM
indyblue
Anyone know where I can get a new head gasket?  It seems OEM is discontinued in all the parts lists now.  I could still get them a couple years ago.
Will the one for a 1200 from RPM work on an 1100?
There are a few on ebay, but I don't know if they'll be genuine Yamaha or not, I don't trust many ebay listings.
Indianapolis, IN `O=o-
1984 FJ1100, 39K mi., custom blue paint, K&N's, jetted, Supertrapps
2005 Pontiac GTO Impulse Blue M6 - gone
2012 Corvette Grand Sport Convertible M6 Crystal Red Tintcoat
1967 Firebird H.O. Conv
Just give RPM a call and talk thru it.  You'll get the no BS answer and be on your way in no time!
the fan
Whats the part number Some sited will allow you to cross reference the part number to any updated number and application. I can run it by the shop I deal with if you have the number.
I an in a meeting at the moment and can't get too creative looking things up.
Quote from: the fan on May 20, 2015, 01:56:29 PM
Don't mean to but in but the original part number was 36Y-11181-00-00.
the fan
Looks like my source failed me. No updated numbers or cross reference listed.
I would check with Randy at RPM. I am almost sure they are available from an aftermarket source.  I see one every once in while on e bay but Randy could steer you straight on which one to buy if he doesn't have any.
Not to confuse the issue but for anybody reading this there is at least 2 different Yamaha head gaskets for the FJ 1200. One has no raised areas I assume to help sealing around the cylinders and one is just flat across.  The flat one is an old version and was superseded by the one with raised areas.  Here is a picture.  Often you will fine the old flat ones on e bay.  Not that they don't work, just they were replaced for a reason.
