It Can't Be This Easy, Or Cheap
Started by FJ1100mjk, May 20, 2015, 11:41:18 AM
FJ1100mjk
I don't care about it this http://www.ebay.com/itm/Motorcycle-Digital-Gear-Indicator-Green-LED-Display-Shift-Level-Sensor-US-/231567808880?fits=Model%3AFJ1200&hash=item35ea845970&vxp=mtr I just keep grabbing gears until they're all gone.
Who'll be the first to attempt its install, for such a low price of admission?
Iron Balls #00002175
www.ironballs.com
copper
I wonder if because it uses a magnet mounted to the shifter moving past the sensor that if you do not fully engage a gear it will read an inaccurate gear reading since it only appears to indicate by the magnet moving past the sensors.
FJ1100mjk
www.ironballs.com
Quote from: copper on May 20, 2015, 12:03:54 PMI wonder if because it uses a magnet mounted to the shifter moving past the sensor that if you do not fully engage a gear it will read an inaccurate gear reading since it only appears to indicate by the magnet moving past the sensors.
Copper,
I was reading about that unit, or one much like it.  The text I saw said that it zeroes itself, every time the Neutral light comes on.  So even if it "misses" a shift now and then, it will correct itself once you hit Neutral again.  For an all-external install, with nothing in the transmission, I'd guess it's fairly reliable.
I bought one, so far it is just another thing on my "to-do" list ...
Paul1965
I picked up a similar one from Amazon only with a red LED, just haven't gotten to installing it yet.
Oldktmdude has one installed and has pics of what it looks like:
http://www.fjowners.com/index.php?topic=11657.15
1978 Yamaha 400 Sold
1984 Yamaha Maxim 400 Blew up
1982 Yamaha Vision Sold
1983 Kawasaki GPz1100 Sold
1984 Yamaha FJ1100 Killed it
1991 Yamaha FJ1200 Sold
2009 Triumph Sprint ST Sold
2014 Triumph Trophy SE
