adjusting screw on carbs
Started by bigbore2, May 12, 2015, 07:29:45 PM
bigbore2
84 1100 with the Mikuni carbs where the pilot jet adjustment is on top of the carb looking straight down from above with tank off.  OK, I'm not really adjusting the pilot jet, but the pilot jet range.
turn in is leaner, out is richer?
BigBore,
I had this same question a while back and documents and opinions were offered up that basically contradict each other.  Wish I could answer that for you, but I'm still shrugging my shoulders.   :unknown:
I'll be watching this thread in case it does get answered.   :good2:
Flying Scotsman
Brass screws are for the air fuel mixture.
If you turn them in you get less fuel and air not just less fuel.
1990 FJ1200
1999 GP1200 (165 + hp)
bigbore2
yes those brass screws. I know it meters both, but the adjustment is still there.
So in simplest terms, is it turn out to lean or turn out to richen??
turbocamino
  turning down= leaner....if you have removed the airbox,try 3 turns out from lightly seated (closed) most all end up around there.
bigbore2
yes Turbocamino- out is richer, in is leaner.
My bike WANTS more fuel, had to up the main 3 sizes, I think and add washers to the needles.  I have gone up in the pilot too and am not there yet. And I am at 5000 ft. Go figure.
Uni pods and 4/1 Yosh exhaust.
A nice write-up can be found in the files section under carburetor files.  I actually looked it up. Pat and Randy contributing.
Flying Scotsman
Tip of the screw protrudes into the throat of the carb so its always drawing air as long as its not closed.Pilot jet is not adjustable without changing to a different size.
1990 FJ1200
Bottomline is it doesn't really matter. Screw them in at half turn increments until the blip test starts to degrade. Then screw them out in half turns until it degrades. Back in a half turn and you're done
