Rally prep
Started by FJscott, May 09, 2015, 05:44:11 AM
FJscott
Leaving for Boone rally in 2 days...definitely broke the 2 week rule
Derek Young
Looks more like you burned the whole rule book Scott! Please tell me you're not bringing the silver and red one in the picture...
Derek
1986 FJ1200 (R.I.P.)
Nanaimo, British Columbia
One of the better boss's I ever had said "Rules and just guide lines"  :lol:.  Press on Scott  :good2:  I like your work space. You clearly need more stuff  :biggrin:
Nice looking work area  :good2:
Hopefully the '92 only needs it's clothes put back on.  :scratch_one-s_head: and a quick shake down ride.
Rock-On Scott!
You've got a nice workshop there!
Wish I had that much space.......... :blush:
Flynt
Quote from: Derek Young on May 09, 2015, 08:44:20 AM
Looks more like you burned the whole rule book...
I'm close to a violation and will cross through 2 weeks to WCR shortly...  about a month ago Randy and I did some electrical work on Wiz (relays on horn, coils, and headlight), then a "what the heck" compression test revealed #2 was way low.  Off came the head and we found some serious carbon buildup from leaking valve seals.  One thing lead to the next and now we're doing pretty much a full rebuild with new cylinders (couldn't get new sleeves in time)...  gonna be pretty again with new paint job on engine, but any little hiccup will DQ the Wiz this year.  Pics...
Backup plan...
Frank , I saw your engine while I was at Randy's the other day and thought you are in for some last minute wrenching .  :empathy2:
If you don't finish it , just put a fork brace on the 1100 and bring it as planned. Nice to have a spare FJ. :good2:
Flynt
Quote from: Mark Olson on May 10, 2015, 03:50:25 PM
just put a fork brace on the 1100 and bring it...
Planning to ditch the Metzler Marbletecs and put Avons on just in case...  I'll go sans brace and just ride slow(er).  Might bring the Duc up for a faster day if Wiz isn't ready.
Derek Young
Wiz's engine sure is lookin shiny! Is it really breaking the rule if you have a backup FJ???
Derek
I got a little more Rally prep done over the weekend as well.
Balanced the carbs with an old school mercury manometer. Works better than the current Morgan device.
It nice to flip the tank around and not need an aux fuel supply.
I finally got the heated grips connected, and found a good place for the switch. I added a simple aluminum bracket to my GPS mount and the switch is tucked away nicely.
Then a temporary volt meter to see the power output of this new to me FJ. A bit bulky, but I already have it, and it will be removed before the rally.
Then a test ride of course on the Crest, being Mother's day the road was all to me mostly.
Next week I will remount the top box, the PO of the rack (not the bike) used a flimsy piece of aluminum as an adapter.  :bad: I replaced the seal in both side bags and swapped out the lock cylinders so all three locks use one key.
Is it rally time yet?
Looks good Mark.  I have a similar set up for carb balancing and find the longer tubes are more accurate.  In rough numbers a 1/8'" movement in a small scale balancer is about 1" of column movement in the longer tube.  Makes it nice to really zero it in and that last bit of adjustment and for me it makes a difference. The smaller units are nicer for portable use or for tool box storage.  Those get you close but once you use the longer tubes you notice that last little nudge of the adjustment screws makes a difference.  They just don't store or transport well :).
Here is what I have been using for fuel instead of using the FJ tank. It is a 1 gal. container from WalMart I think.  Run a fuel line in it. The filter is a lawn mower filter.  Applies to fuel pump models.  Under the towel I have a small piece of plywood it rests on.
I haven't had time to do it but I have though about trying to attach an inexpensive low PSI pump with an adjustable regulator 1/2 PSI to 6 or 7 PSI with a 1 gal fuel container all in one box.  So it could be used with gravity or pump FJ's for balancing carbs.   Might be handy for rally's or shed days :).
You might need those heated grips plus rain gear :) http://www.wunderground.com/q/zmw:96133.1.99999 I like the 10 day forecast graph when you scroll down. (just promoting the WX site).
Safe travels Mark.
Flynt
Quote from: Flynt on May 10, 2015, 12:29:11 PM
Backup plan...
So as the WCR draws near and Wizard is throwing repeated curves at us, we shifted attention to the '84.  Here's a pic after spending some time at RPM on Sunday:
How many changes can you see...?
Quote from: Flynt on May 19, 2015, 11:13:52 PM
I see a fork brace and exhaust mod. You still have the crappy tires... It is hard to see from prior pics... I am also guessing the spin-on oil filter...
Flynt
Quote from: FJmonkey on May 19, 2015, 11:23:47 PM
Yep...  hoping for new tires soon (Avons on order).  It was stock except for the stainless lines going in.  Other observations?
Well, you have your side stand down while on the center stand, WTF?
