Plug and play masters
Started by fuel80guy, May 03, 2015, 03:19:31 PM
fuel80guy
I'm looking for a list of plug and play.master cylinders for both clutch and brakes in 14mm.
That's a great idea. Let's start a list and I'll copy and paste it down to the Mod Files.
I use a 2002 FZ1 brake m/c and a 2005 FJR clutch m/c. The FJR uses a 3 wire switch so you have to figure out which 2 prongs you need to connect to the FJ 2 wire leads....I think it was the 2 outside prongs on the FJR switch I used...not sure.
Honda VFR800 brake and clutch work, the banjo bolt connection is 90 degrees different than stock.
Honda VTR1000 brake and clutch work, the banjo bolt connection is 90 degrees different than stock.
2010 Kawasaki ZX10R brake master works.
fuel80guy
Good to know about fjr as I have one but thought it didn't work because of different pins.
