Please Please read this if you run a R1 rear wheel
Started by Russfjr1, April 30, 2015, 07:30:04 AM
Russfjr1
I have been looking at bearings if you have looked at my other posts.
I was alarmed to say the least when I found that the sprocket carrier bearing has the part number 6206 on it (albeit on the black seal).
If you have changed your sprocket carrier bearing and used this part number your bearing is not correct, the rear spindle has a OD of 28mm BUT the 6206 bearing has a ID of 30mm therefore the bearing is only acting as a spacer not even touching the spindle.
If this is old news that's fine would rather be going on about it than people not knowing.
It's about as useful as a chocolate fire guard
Current bikes in the stables
Yamaha FJ1200
Yamaha FJ1100
Honda Monkey-bike z50m 1967
Ducati Monster
Ducati ST2
Triumph Daytona 600 (daughters)
Honda CBR1000RR (daughters)
Pretty sure it's supposed to be a 62/28.  Measurements are 58mm OD, 28mm ID, 16mm wide.
If you look at the Yamaha parts fiche it shows a 6205 bearing -- NOT the first time Yamaha listed a wrong bearing number for a wheel........caused me headaches on two different wheel swaps
What year R1 wheel are you running?  What swingarm?  What shock/linkage setup?
Russfjr1
Quote from: fj1289 on April 30, 2015, 03:02:46 PM
OK the cush drive bearing is 28mm ID 62mm OD and 16mm thick, as to the year of the wheel unknown but three spoke (will look for part numbers) swing arm is 2010 R1 big bang and the shock links I am in the process of making.   Russ
Yamaha FJ1200
Yamaha FJ1100
Ducati Monster
Ducati ST2
jscgdunn
On my conversion (2008 R1) I have used all the stock shock linkage.  Shock is 2013 Honda CBR1000RR.
Jeff
90 FJ 1200 (Son # 2), Stock
