Mistress getting Mod Fever!
Started by Sabre093, April 25, 2015, 04:43:49 PM
fj johnnie
 He was eyeing a used one, but someone bought it with unearned auto worker money!
Sabre093
Well she's Back!!!!Ended up going with a 89 GSXR 1100 set-up still happy with it,going to re-visit the 93 once i get more info!
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
Quote from: Sabre093 on May 10, 2015, 07:31:35 PM
I doubt that you'll get much real improvement by going to a 5.5 instead of the 4.5" wheel you have.
Both have current technology tires available.
Both use tires that are 'low profile' and have short sidewalls.
OEM for FJs was a 150 section tire, and the 4.5" rim will happily take a 160 (or a 170 if you really feel the need to go phatt.
With a 5.5" wheel you can use a 180, but some 180s are too wide and require you space the chain run further outboard.  Is that extra 10mm (nominal) important?
Sabre093
Yes my thoughts exactly. ...probably  go to the 170 though
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
the saying goes like this..."LESS IS MORE AND TOO MUCH IS JUST RIGHT" ...  :good2:
hawkaholic37
Hi guys...l have been reading this thread, and l can't say l completely follow the whole process, but hoping that once l get a bike and get in there it will all come together and make more sense.
The bike l am going to look at this weekend is a '92 and it is bone stock.
There is an '89 FZR1000 in my area that is getting parted out, it is complete, and l am thinking that l might want to jump on some parts from it, either for the bike l get, or for someone else who needs them down the road.
I have a few questions...
The FJ got a 17" wheel on the later models...would it be the same identical wheel as the one on this FZR?
I have read that some guys like to swap out the forks with the FZR forks. Would the 1989 FZR forks be a simple swap on a '92 FJ? Would l also want to go with the FZR wheel, or would it matter?
How about the rear wheel?
Any other good parts that can be scavenged from this bike?
2004 Suzuki SV650S    Current
1999 Honda EX400    Past
1971 Suzuki TS250    Past
1982 Honda XR250R    Past
1985 Honda VF700S Sabre    Past
1981 Honda CM400    Past
1986 Honda Spree (Weehawwww!!!)    Past
1978 Suzuki PE175    Past
The FJ front wheel is 3" wide, the FZR1000 wheel is 3.5" wide. The difference to me is using a 110 vs. a 120 wide front tire. If you don't carve the canyon corners then you can pinch a 120 on a 3" wheel. Hell.... I did that while running the Crest for a few years... The 120 is better for a 3.5" and the 110 is is better for a 3". But if you are not looking for knee dragging performance then enjoy and ride it...
oldktmdude
   The '89 FZR1000 has a 17mm front axle so it's not a straight swap. It can be done. The rear wheel can also be made to fit the FJ. This also is not a straight swap.  Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
hawkaholic37
Thanks guys. l haven't heard back from the seller yet, so who knows what will come of this. l am thinking l might grab them if they are cheap, but will not spend big money.
Quote from: hawkaholic37 on July 06, 2015, 09:06:27 PM
1st Generation FZ1 is a better option in my opinion........ you get 43mm diameter fork tubes and cartridge forks with 3.5 x 17 wheel and the swingarm is pretty easy swap with 5.5 x 17 rear wheel. There is a bit of machining involved but nothing that can't be done fairly easily in your own workspace or have an engineering shop do for you.
There are posts about mine here somewhere or ask and I can detail it again.
A first gen FZ1 is also a pretty good substitute for an FJ.
Get your FJ first and ride it.  You might not want/need to do any conversions.
The first money should be for RPM fork valves and rear shock anyway.
hawkaholic37
Quote from: FJ_Hooligan on July 07, 2015, 04:02:56 PM
Yeah, that seems to be the concensus.
