Installed Brake light modulator
Started by aviationfred, April 21, 2015, 07:43:58 AM
While looking for parts and upgrades for the Vmax, I came across this simple and inexpensive tail light modulator.
http://www.ebay.com/itm/161518769345?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_3735wt_1153
2 wires in, 2 wires out. Super easy to install.
I have LED tail/brake lights and it works great.
Country Joe
Quote from: aviationfred on April 21, 2015, 07:43:58 AM
Fred,
Does it strobe then go to solid?
1993 FJ 1200
Every time a brake switch is made, there is 4 super fast flashes, 4 slow flashes and then the brake light stays on until you release the switch.
I will post a video later this evening.
Country Joe
Quote from: aviationfred on April 21, 2015, 09:34:54 AM
Fred,
Thank you, that sounds perfect to me.
1993 FJ 1200
Quote from: Country Joe on April 21, 2015, 09:45:54 AM
Fred,
These are an excellent safety feature. Having had one for a couple of years I have had many people comment on how eye catching they are.
They only work with LED globes though.
If I'm concerned about a car approaching from behind when sitting at an intersection, I just release the brake and reapply it to set off the flashing sequence again. It is adjustable for flash rate and duration before going solid.
A rapid flashing LED is hard to miss.
Thank you Fred, I just ordered one....It's been on my list for several years now...long overdue.
Skymaster's Check Your 6 post about the Lancaster fatality is a reminder.
Paul1965
I used a cheap one like this on my 84 and it worked great (I think I held out for a Chinese model that was under $5). I did the same thing as Fred, release then grab the brake again just to get their attention behind me. If you run LED turn signals with built in brake lights (the sword style) you can wire this to those at the same time.
1978 Yamaha 400 Sold
1984 Yamaha Maxim 400 Blew up
1982 Yamaha Vision Sold
1983 Kawasaki GPz1100 Sold
1984 Yamaha FJ1100 Killed it
1991 Yamaha FJ1200 Sold
2009 Triumph Sprint ST Sold
2014 Triumph Trophy SE
Thanks Fred. I also put one on order.  :good2:
Russfjr1
I like it but will it pass a UK mot?
It's about as useful as a chocolate fire guard
Current bikes in the stables
Yamaha FJ1200
Yamaha FJ1100
Honda Monkey-bike z50m 1967
Ducati Monster
Ducati ST2
Triumph Daytona 600 (daughters)
Honda CBR1000RR (daughters)
Quote from: Russfjr1 on April 22, 2015, 07:08:26 AM
The install seems simple enough, when you get your MOT inspection just remove it. Reinstall after you pass...
Thanks for the heads up Fred.
Placed my order this morning.
Man, we are going to be a bunch a LED flashing Mo-Fos at the rally this year!
I used Molex connectors to install the modulator. If it fails, or I need to remove it for any reason. I can un plug the modulator and connect the factory wires together.
Received mine today. I will install it Monday.  :good2: :good2:
