general questions
Started by theLeopard, April 13, 2015, 06:29:10 PM
theLeopard
Had some general questions you guys probably know the answers to.
Where are synchros located & how do you engage 1st gear without them?
Is there a rule-of-thumb for cornering speeds? Fir exapmle, 2x the recommended posting. (Im not there yet but am practicing and dont want to exceed physical tirelimits from ignorance)
Recommended rears? I just installed a Pilot front.
Recommended oil? Is Yamalube sufficient with regular changes?
Importance of jetting?
Loss in mpg after #40 upgrade?
Why are the jets variable? How does where they sit in the carb affect fuel delivery?
(popcorn) hi
1992 FJ1200
Quote from: George"It is What It Is Until It Ain't Anymore"
The
Quote from: theLeopard on April 13, 2015, 06:29:10 PM
There are no synchros.  If there were, they'd be in the transmission
All depends on the particular roads authority and their standards when posting corner suggestions.
Note: These posted advisories are usually intended for heavy trucks.
Temperature, level of moisture, choice of tires, your skill and courage level all affect potential cornering speeds.
There is no limit on ignorance
On OEM rear wheel?  Lots of discussion on this topic - Search
Yes. So is 'diesel' oil. So are Synthetic Motorcycle oils. You won't have the bike long enough to see differences in oil protection properties
Allows the engine to operate (close to) the proper stoichiometric ratios with both efficiency and power
Depends on how much time you spend at or just slightly above idle
To provide correct fuel/air ratios. Read a carburetor theory manual
Hope that helps your understanding :-)
theLeopard
What was all that business the last few days about synchros?
Autos only? Our scooters operate on plate friction, yes?
Also, how long do you figure the bike can last?
Why wont i have it long?
300,000 mile kinda thing?
You've helped my understanding greatly, Arnie. Thanks mate!
1992 FJ1200
theLeopard
Im reading some introductory theory.
In a 4stroke, like my FJ, there are an even number of cylinders which fire alternately in a linked system so there will always be a power stroke coupled with an intake stroke yes?
And the exhaust/compression stroke is powered by mechanical inertia?
1992 FJ1200
theLeopard
Are jets the "venturi" chokepoint in my FJ carb?
1992 FJ1200
theLeopard
Are float needles the functional part that metes the air being mixed with the fuel flowin through the jets for combustion?
1992 FJ1200
theLeopard
Oh.... Jamming the throttle from nearidle is really hard on the bike.....
:blush:  :empathy3:
1992 FJ1200
theLeopard
Prevailing symptom of running 'rich'?
Also, the flaots arent for air. I shoulda remembered that from when i rebuilt my carbs but im trying to unpuzzle this manual.
1992 FJ1200
yamaha fj rider
Quote from: theLeopard on April 13, 2015, 09:56:56 PM
"Also, how long do you figure the bike can last?"  That is up to the owner 100%.
"300,000 mile kinda thing?" There are FJ's out there with over that many miles. More than a few with over 200,000 miles.
"Why wont i have it long?"  Best case scenario. You will get tiered of it and sell it.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
theLeopard
Yeah thats why im asking why he said that....  :sorry:
1992 FJ1200
theLeopard
Are the air mixture screws located in the carb bowl or elsewhere?
1992 FJ1200
theLeopard
If my bike limits at 100mph is it because my main-well tube is clogged or is a governor installed on my machine?
1992 FJ1200
Quote from: theLeopard on April 13, 2015, 11:32:15 PM
When you say limits, it it cutting in and out like a rev limiter, or just won't push any faster?
theLeopard
Just won't push.
I hit the governor in my accord & governors produce a bouncing effect when you reach the programmed limit.
Theres no bounce, it just wont continue accelerating.
1992 FJ1200
yamaha fj rider
IMO. For whatever the reason. I suggest you consider it a gift from God. Helping to keep you alive. With that good night.
Kurt
93 FJ1200
FJ 09
Tenere 700
FJR1300ES
