84 FJ1100 Dusted off After 10 yrs, Help
Started by Sparky84, April 09, 2015, 03:40:24 AM
You need a good deep cleaning of all passage ways and jets.  IMO just buy new pilot jets.  And don't forget to pull out the emulsion tubes.
Sparky84
Bike is going and usable and once I clean carbies 1 last time (for now anyway) and after I put new kits in and tune them,
then check valve clearances, what else should be done?
In the manual it says 10/30w motor oil for forks, is this correct?
I have what I think is standard gearing with 17/42 and always seems to be revving too hard, any suggestions would be good.
Should I replace all brake cylinder seals or just the fluid?
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Sparky84
Just checked on RPM site for carb kit, it says out of stock for 84 FJ1100
Can I buy a 86 FJ1200 kit and buy other jets to suit?
1979 Kawasaki Z1300
Urban_Legend
With the gearing - I run 17/40 and that give around 4500 rpm at 100KPH. With 17/42 it should be like riding a unicycle - only one wheel on the ground. Would probably not hurt to put kits through the brake and clutch MC. Can't help with the weight of the shock oil.  Depends on your weight and how hard you like the ride.
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
FJ1100mjk
Quote from: Sparky84 on April 15, 2015, 07:04:16 AM
If you can't get your supply from RPM Racing after emailing or calling them direct, you can get your carb kits here:
http://www.z1enterprises.com/ShopByCategory.aspx?name=Carb&description=Petcocks+carb+kits+petcock+rebuild+kits+etc&category=01010305050102
They're a stand-up supplier too. I've used them for items myself. Mostly Kawasaki parts, but FJ stuff too.
Good luck!
Iron Balls #00002175
www.ironballs.com
Bones
Quote from: Urban_Legend on April 15, 2015, 08:55:42 AM
Are those revs right Mark, I'm running 17/39 on mine at present and 100 kph is about 3700 rpm
93 fj1200
79 suzuki gt250x7
Urban_Legend
Quote from: Bones on April 15, 2015, 04:02:30 PM
That's what my gauges are telling me Tony. I know the speedo is only out by 2kph, and the sweet spot where all the vibrations disappear is 130 @ 6000 rpm. Maybe I am wrong on my cogs, but 17/40 is what I ordered.
Mark
Mark
My Baby (Sparkles)
oz.fj
Quote from: Sparky84 on April 15, 2015, 05:57:27 AM
Hey Sparky
I and others have had good results from using 15 weight fork oil.
130mm down from the top of the tubes measured with springs out and full compressed .
Darran
89 FJ 1200 Shiny Black
89 FJ 1200 x 3 Red White Silver
92 XR 250
Life is pretty straight without twisties
Bones
Quote from: Urban_Legend on April 15, 2015, 04:51:22 PM
Mark
Have a play around with this Mark, to do those revs at that speed with standard tyres and 17 tooth sprocket on the front, you would need a 48 tooth sprocket on the back. I assume the internal gear ratios between the FJ 11/12 are the same, so there's something skewy somewhere. :pardon:
http://www.gearingcommander.com
93 fj1200
79 suzuki gt250x7
Here you go, complete kits, good quality, great price. http://www.motorcyclespareswarehouse.com.au/products/ky-0559-carb-repair-and-parts-kit
I just received 4 kits for my '92, unfortunately our crap dollar still is stopping me from ordering overseas from Randy. I gave up trying to clean my emulsion tubes etc, they were disgusting.
Troyskie
Quote from: Sparky84 on April 13, 2015, 07:14:51 AM
Caution following images might be disturbing
It's a tribute to the FJ it ran at all
Urban_Legend
We can check it out at the men's  shed day Tony.
Mark
My Baby (Sparkles)
Quote from: Urban_Legend on April 16, 2015, 07:51:56 AM
Urb, are you sure you were in 5th when you checked the revs? You wouldn't be the first.
One of our esteemed, long time owner and big mileage members rode a very long way in 4th on the open road once (not me)
Urban_Legend
Quote from: ribbert on April 16, 2015, 10:26:13 AM
Hey Noel - No. Pretty sure in 5th....used to riding a 6 speed bike and I keep looking for one more gear. But I have been known to be wrong before.
Mark (sorry if I am hijacking your thread Sparky)
Mark
My Baby (Sparkles)
Sparky84
Quote from: X-Ray on April 16, 2015, 05:06:19 AM
I have been looking everywhere for something like this nearby.
Had a look, not a bad price and in stock but I have read a few things bad about Keyster Carb Kits,
mainly with slide needle shape being different and not performing properly in mid range and some parts not looking the same as what they are replacing
But maybe as usual when products don't perform everybody speaks up and when they are good no one says anything because they're satisfied
1979 Kawasaki Z1300
