gas cap flapper
Started by Tapartacus, April 05, 2015, 08:12:08 PM
Tapartacus
So I took the flapper valve out of my 89. Managed to save the microscopic ball bearing. However now I can't seem to figure out how to put it all back together! Anyone have have an exploded view of this? Thanks
Andrew
92  FJ1200
89  FJ1200
This might help. Open the PDF in the first post.   http://www.fjowners.com/index.php?topic=2024.0
The spring and ball help the tumbler stay in position so the key/lock doesn't "flop" around.
Tapartacus
Thank you George!! Just What I needed.
Regards
Andrew
92  FJ1200
89  FJ1200
No problem. The third photo down shows the spring.  The ball go's in the channel then the spring then the bracket in the photo to hold the assembly in.
Tapartacus
Unfortunately I broke the spring that holds the flap over the key hole :(  But because i was able to keep the spring and ball, at least the flap stays up when I need it to and down when done fueling. There's just no real tention on it anymore. Oh well, thanks again.
Andrew
92  FJ1200
89  FJ1200
