carb sync
Started by Cash Dereszynski, March 30, 2015, 06:29:35 PM
Quote from: Cash Dereszynski on April 21, 2015, 09:19:07 PM
Quote from: Mark Olson on April 21, 2015, 02:34:22 AM
how is the gas cap vent? I see a magnetic tank bag in the pic ... they are known to cause a vacuum lock and starve carbs.
I never heard that one before.
Cash
The early model gravity fuel feed fj,s have this problem..It can be corrected by removing the flapper valve inside the gas cap..then you can still use magnetic tank bag without further problems. If you suspect this happening ,try riding with gas cap open and see if problem goes away..
Cash Dereszynski
WTF.
Adjusted needles irratic running , pulled it apart will check tank vents and petcock again . Going to check Float bowl height. Getting to th point of a ride to RPM....
Pix Left to right.
Cash
Fuck it,let's ride.
Pilot jets!  Clean them again.
Cash Dereszynski
Pulled the carbs checked the float level all at 22mm, all ports clear. reassembled and now I wait for a new vacuum petcock. It's got to be the petcock!
Cash
Fuck it,let's ride.
