Gixxer rear wheel mod
Started by scotiafj, March 26, 2015, 02:50:29 PM
scotiafj
Hi Im doing the gixxer rear wheel swap and was wondering you guys that have done it what length of rear brake hose did you use ? was it the fj one or a standard length gixxer one or longer ??  thanks Scotia :)
I used Galfer as the brand and standard length 1992 GSXR750 Baided line for mine
scotiafj
Thanks very much for the reply  :good2:
Here is what I did:
The loop.
The anchor on the chain tension bolt.
The anchor bracket - I have 4 Monkey made of these left.
The length - original was 28.5", now 27.5"
The end at the master - Top is current, bottom is a better angle if you can find it.
Quote from: FJmonkey on March 26, 2015, 05:03:12 PM
Here is what I did:
The loop.
I've often wondered about the over the top routing, is there any reason it can't go directly from the m/c to the caliper, like below?
Quote from: ribbert on March 26, 2015, 09:01:43 PM
Clearly it can, please post more on how you did it....
